Old 03-07-06, 11:21 AM   #61
21QUEST
21QUEST's Avatar
Ok , I've got a proposition for you. I've got a set of calipers in good nick last time I checked. I've not had a standard front end for ages. I'll clean/regresed them so all you have to do is bolt them up.
PM your address and I'll do my best to stick it in the post tomorrow. Let me how urgent you need it so I choose the appropraite service.
Try that out (I it looks like the problem is the forks) but if you think there may also be aproblem with the caliper then you could try that. I dunno now , but maybe the caliper bracket is bent? I think Svrash had a problem with his some time ago.
Anyways offer is there if you want to do that.
Ben
Nemo me impune lacessit.
Old 03-07-06, 11:37 AM   #62
goof
Hi Ben,
That's incredibly good of you, will PM you.
Old 03-07-06, 11:53 AM   #63
Old 06-07-06, 07:40 PM   #64
goof
Just a quick update - got the calipers off 21Quest today (cheers Ben ) and they slid straight on!
It was indeed the caliper bracket I'd mentioned earlier that is supposed to slide in and out (mine was solid). Thanks for the other suggestions though (and at least my spacer's set correctly now!).
Old 06-07-06, 07:45 PM   #65
TSM
The Sick Man
TSM's Avatar
So the disk was being scraped by the fork leg not being fitted properly and then once that was sorted it was found that the caliper was not sliding on the mounting bracket.
Old 06-07-06, 08:25 PM   #66
goof
Yeah, kinda, was mainly caliper mounting seized I think (the spacer distance wasn't major so maybe would have 'got away' with it had the calipers been ok - glad to have both sorted though!).
Old 06-07-06, 08:26 PM   #67
Warren
at least you got it sorted now.
Old 06-07-06, 10:38 PM   #68
Thank **** for that!
Old 07-07-06, 12:50 AM   #69
21QUEST
21QUEST's Avatar
You can say that again
Ben
Old 07-07-06, 01:08 AM   #70
Thank **** for that !
Brake light probs Baz SV Talk, Tuning & Tweaking 9 24-09-08 08:07 AM
reg rec probs maybe dizzyblonde SV Talk, Tuning & Tweaking 4 27-09-07 04:07 PM
more probs hovis Idle Banter 6 02-10-06 09:05 AM
Front brake probs, advice needed. Dirty Baz SV Talk, Tuning & Tweaking 14 21-03-05 04:18 PM
sticking brake pt 2 (got some lovely pictures ) *update* Warren SV Talk, Tuning & Tweaking 18 24-01-05 04:59 PM
