Old 16-12-08, 09:10 PM   #71
Miles
Default Re: Which GSXR shock (again.....)
Originally Posted by silent11 View Post
incorrect you can just move the under tray back which requires 2 holes drilled in tray and about half inch taken of the top of the tray
Any more pics or details of this around? Did you take the the rear fairing panel off?
What do you mean by the top of the tray?
Old 16-12-08, 10:33 PM   #72
Lozzo
This is how I fitted my shock and modified battery box.
http://www.flickr.com/photos/78131584@N00/page4/
I hated the look of the unused toolbox under the battery so chopped that off at the same time.
Old 17-12-08, 10:27 AM   #73
Paul the 6th
Paul the 6th's Avatar
.....Stick a hagon Ohlin etc on. yes expensive.....
hagon ohlin
Old 17-12-08, 12:31 PM   #74
silent11
basically
i first had to take the rear fairing off
remove battery and it will revile 2 bolts undo them, further back are 2 bolts each side connected to the rear sub frame undo them and the tray should be free to move
once you have moved it back a little you will have to re drill 2 holes on the battery box ( you cant see them as they are covered)
at the end of the tray where it hits the lights you will have to cut a little for it to fit correctly, take your time
then you will need to fabricate 2 brackets about 2 inchs long and drill 2 holes on each bracket this will allow you to connect the 2 rear holes at the back (again this is covered so you wont noticed the difference) and reconnect every thing back
it may seem alot of work but after reading through different ways this looked like the cleanest and easiest way
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
K4 GSXR 600 Shock into a K1? mattyL Bikes - Talk & Issues 5 18-05-07 05:48 PM
05 gsxr shock dropit987 SV Talk, Tuning & Tweaking 11 22-07-06 10:54 PM
GSXR shock on a K3 lukemillar SV Talk, Tuning & Tweaking 9 05-04-06 09:30 PM
For sale GSXR 750 K5 Shock (SV 650 K3 on shock upgrade) alien19779 For Sale - SV's and SV related items 0 28-03-06 01:16 PM
