Old 10-03-09, 09:16 AM   #71
Dave20046
Dave20046's Avatar
Default Re: bleeding brakes - problem
Originally Posted by jamesrichardson View Post
ok, then you close the banjo up before releasing the lever? (sorry if its obvious, just trying to rule out some things)
Yeah I did (don't worry about it I often make stupid mistakes, glad you're being thorough!)
Old 10-03-09, 09:17 AM   #72
jimmy__riddle
ok, if you do the same, pull the lever in, quickly crack open and close the banjo at the caliper end is there pressure?
Old 10-03-09, 09:19 AM   #73
Dave20046
Dave20046's Avatar
Pressure in the fluid or pressure on the lever?
The fluid just dribbles out the same, the pressure at the lever stays constant (still very spongey!)
Old 10-03-09, 09:24 AM   #74
branny
I had this problem, what i found was that i had to lean the bike over to the right as far as i could, with the bars turned to the right. Then pump the lever and you see bubbles coming out. These bubbles may be trapped when the bike is vertical and certainly if the bike is to the left.
I did my front calipers twice and this worked both times after having the same issue.
Old 10-03-09, 09:24 AM   #75
jimmy__riddle
pressure in the fluid.
if the levers not working enough to put pressure in the fluid use the syringe to back fill from the bleed nipple under pressure leave everything untouched (lever etc) and push fluid in under pressure until you can push anymore in then close the nipple. pull lever in and crack banjo at lever open and closed quickly. then push fluid in as before and repeat. its probably still air in the hose.
Old 10-03-09, 09:40 AM   #76
Dave20046
Dave20046's Avatar
I have tried that but maybe worth another go.
Old 10-03-09, 09:40 AM   #77
Dave20046
Dave20046's Avatar
Thanks branny I'll give that another pop.
Old 10-03-09, 09:42 AM   #78
jimmy__riddle
i had to do it 3-4 times before my lever felt like it was doing anything
Old 10-03-09, 09:49 AM   #79
Dave20046
Dave20046's Avatar
Right, I'll give all that a go tonight. I'll let you know how I get on
Old 10-03-09, 08:17 PM   #80
Dave20046
Dave20046's Avatar
Tried all of the above again...still no joy
Bleeding Brakes - Again HopefullySoon SV Talk, Tuning & Tweaking 2 28-08-07 09:13 AM
Bleeding Brakes (Bleeding Kits) 21QUEST SV Talk, Tuning & Tweaking 8 20-06-06 05:31 PM
Bleeding Brakes sweepdoggydog SV Talk, Tuning & Tweaking 9 08-06-06 07:07 AM
Bleeding brakes Samurai SV Talk, Tuning & Tweaking 6 06-06-06 05:17 PM
Bleeding Brakes Moo SV Talk, Tuning & Tweaking 9 21-01-06 07:59 PM
