Old 25-04-10, 07:10 PM   #71
davepreston
Default Re: Which GSXR forks etc? (Yet again).
will do
Old 25-04-10, 09:14 PM   #72
barwel1992
what is the sv k3 top head bearing ID (where steerer tube passes through) and the OD of the gsxr 1100 steerer tube
and whats the height of the k3 bearings or does the spacer not need to be the exact hight of the bearing inner
Old 26-04-10, 02:49 PM   #73
barwel1992
any one ?
Old 26-04-10, 02:51 PM   #74
oldskoolsuzuki.info there's a table in PPs pages with bearing data.
Old 26-04-10, 02:55 PM   #75
barwel1992
thanks
Old 26-04-10, 03:16 PM   #76
barwel1992
ok the gsxr 1100 bearings are 25mmID 47mmOD 15mm Height
and the sv is 30mmID 55OD 17height
the the spacer needs to be 30mm OD x 25mm ID x 17mm height, does that need to have like a top hat or any thing to hold it in the bearing ? or just a cylinder type spacer ?
Old 26-04-10, 03:46 PM   #77
barwel1992
found a perfect spacer ?
LINK
and the bottom bearing will just slot right in to the k3 frame bottom ?
any thing else i need apart from the spacer to fit the front end ? apart from the lock ring tool, how many lock rings do i use the sv has 2 gsxr 1100 has 1 ?
EDIT nope right spacer i think lol
Old 26-04-10, 04:51 PM   #78
Dave20046
Dave20046's Avatar
only thing that's bothering me is getting the spacer for the bearings, will get the forks serviced professionally so seals ant a issue
I'd contact yorkiechris or someone - see if he's willing/able to do it for you. Bound to be cheaper
Old 26-04-10, 05:32 PM   #79
barwel1992
never mind dave has sold the forks
keep on hunting
Old 26-04-10, 05:35 PM   #80
barwel1992
what about these lads ? LINK
Fitting GSXR front mudguard to GSXR USD forks maviczap SV Talk, Tuning & Tweaking 1 20-02-10 10:05 PM
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
K7 GSXR 600/750 or K8 GSXR 1000 Forks shelleyamy SV Talk, Tuning & Tweaking 17 04-07-08 07:51 AM
GSXR 600 K5 forks gruff SV Talk, Tuning & Tweaking 4 17-04-07 09:36 AM
which GSXR for forks svrash SV Talk, Tuning & Tweaking 29 15-02-06 09:15 AM
