Old 27-09-09, 10:34 PM   #81
xXBADGERXx
Default Re: rear shock change
You will have to cut on a K3 with the 1000 shock .
I could have done mine better and tidier but I had to get the bike back together in a hurry
Old 27-09-09, 10:42 PM   #82
barwel1992
^^^ thats the pictre i have been after for like 3-4 days and couldent find one thanks verry verry much so what did you do with the batery did it just fit in without the feet on the seat
Old 27-09-09, 10:45 PM   #83
xXBADGERXx
It`s in my Shock Change thread
Old 27-09-09, 10:55 PM   #84
barwel1992
found you thread but nothing about the battery in there :/
Old 27-09-09, 11:05 PM   #85
xXBADGERXx
Post number 4 in this thread http://forums.sv650.org/showthread.php?t=112527
Old 01-10-09, 11:51 PM   #86
barwel1992
is the 99 gsxr 1300 shock to hard for a 17stone + rider (pillion use as well and thats in gear)
Old 02-10-09, 09:16 AM   #87
MF4
Originally Posted by CheGuevara View Post
Here's my personal list. Highlighted bits were just me narrowing down my best options (for a pointy) with regards to maintaining similar length and an appropriate rate. I decided on, and used the 05/06 ZX6RR shock (I'm 6'4" and ~240lbs + gear) -which seems to work well.
I've fitted a K6-k9 600 Gixer shock to my K5 SV, but I've also replaced the "dog bones" to raise the tail..
It's a great shock but very difficult to setup properly
I think it's waste on a SV but... it gives a good feeling on track!
Old 02-10-09, 05:23 PM   #88
barwel1992
i keep been told a zx14r or zzr1400 shock is what i should go for on the svrider forum but they are to expensife :/
Old 03-10-09, 07:00 PM   #89
xXBADGERXx
Well you can pick the brains of everybody on either site til the cows come home , GSXR shocks have worked well for the Majority of us and some of us have used Kawasaki ones , I personally am a heavyweight , carry the Mrs on the back of the bike and have had it loaded up with luggage and my GSXR shock has coped admirably . I have left it on the settings that it was given to me in , and it has been fine for one up blatting , 2 up cruising on motorway speeds with luggage and 2 up slinging about on the twisties around North Wales ........... total price ?
£50 for the shock
£4:50 for the bolt
An hour and a half of my time and the best single modification you can make to an SV for the money .
Old 03-10-09, 07:02 PM   #90
Dave20046
Dave20046's Avatar
£50 for the shock
£4:50 for the bolt
Agree, I found uprated fork springs complemented it though. Not sure if everything was set up right but standard springs were bottoming the forks out and generally felt a bit wallowy.
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
