Old 23-11-07, 01:49 PM   #1
adam_castell
Default offset woodruff key install, puller tool required
i am about to install an ignition advance key, im reading through the instalation instructions, and i need a rotor pullet tool which is basically an M20 x 1.5mm bolt. ive talked with our purchasign department at work, who have tried to get hold of a bolt for me, but its quite a rare size, M20 are normally 2.5mm pitch thread. they are all special order and cost a BOM, plus there is a minimum order quantity.
does any one have a bolt of this dimension or the actual suzuki special tool (
Suzuki p/n 09930-304450) which i could buy or borrow?
cheers
Adam
Old 23-11-07, 03:25 PM   #2
Default Re: offset woodruff key install, puller tool required
Is there space to get a normal puller in there? Can't remember from last time I had mine in bits.
Old 23-11-07, 03:29 PM   #3
adam_castell
i think there most likely is enougth space, its just finding a puller tool with the right thread, and ive just spent alot of money on parts, im startign to run a little low now! lol
Old 23-11-07, 03:36 PM   #4
I mean a 3 legged puller, could be worth a try, most mechanics have a selection
Old 23-11-07, 04:41 PM   #5
454697819
PM northwind, he has one that was doing he rounds i think, if not he was in posession of one doing the rounds... or someone had one doing the rounds...
either way, there is one around here somewhere.
Old 23-11-07, 04:48 PM   #6
Richie
fantabulas
Richie's Avatar
I've got one also, But I bought mine from a Fastners shop, for only £3.50
My Flickr photos
Old 23-11-07, 05:26 PM   #7
r4ce_e3nd
I've got also a bolt laying around I not using anymore, but it will cost you more to send it to you than buying a new one.
Old 23-11-07, 05:53 PM   #8
zadar
no room and not good idea to use it.
Old 23-11-07, 08:58 PM   #9
adam_castell
ok, thank you everyone, i cant seem to find one on ebay, can anyone point me in the right direction or send theirs and give me the bill for the postage?
cheers
Old 23-11-07, 09:03 PM   #10
zadar
fyi.I have tested various degree changes,from 1-8 degree in each direction on stock bikes and found no difference worth mentioning.all test done on same day on same dyno.
all runs were within 1hp.
offset woodruff key / ignition advance adam_castell Stuff Wanted 0 12-11-07 02:52 PM
Offset Woodruff key to advance ignition by 4° Richie SV Talk, Tuning & Tweaking 1 22-07-07 06:20 PM
I need a rotor puller tool svrash SV Talk, Tuning & Tweaking 8 22-03-06 03:58 PM
Flywheel Puller Tool TSM SV Talk, Tuning & Tweaking 1 02-01-06 04:34 PM
Rotor Puller Tool TSM SV Talk, Tuning & Tweaking 6 07-12-05 06:24 PM
