Old 10-12-07, 10:06 AM   #1
Paul the 6th
Paul the 6th's Avatar
Default LCD Display shows "CHEC" after engine has been running for a while?
Picked my 05 sv up on friday from rotherham & it's cursed. Within 15 minutes of collecting the bike a woman rammed into the back of me whilst waiting to pull on to a roudabout in rotherham. There was no visible damage & it was only a low speed shunt luckily... just felt like someone pushed the bike forward 6 inches with a good kick. Then when I got back into Dewsbury a woman ran a red and nearly had me off. Now for the technical stuff:
(ignition on/engine not running /\)
Now, when the bike has been running for a few minutes (whether stationary or riding up the motorway as I was when I first noticed it) the LCD below the trip/odometer shows "CHEC". I've checked the handbook and it says make sure the kill switch is switched so the engine is on (which it is) and ensure the side stand is properly up. I haven't had chance to take her out since friday so I haven't checked to see if it was the side stand but I'm 99% sure it wasn't that since the engine didn't cut out when in gear etc.
The handbook also says "If the display still indicates "chec" after above procedure, inspect the ignition fuse & connection of lead wire couplers." - Could anyone advise on this?
Old 10-12-07, 10:17 AM   #2
plowsie
Default Re: LCD Display shows "CHEC" after engine has been running for a while?
Check oil? Dunno, ent got a pointy mate, assuming it means check summit.
Old 10-12-07, 10:19 AM   #3
Sudoxe
Check the kill switch. I seem to remeber that message coming up when it was off.
I dont believe its the tip over sensor because that gives a FI warning light, afairc.
Dan
Old 10-12-07, 10:37 AM   #4
Lozzo
If you bought it from a dealer then take it back and have them check it. Before you do, check oil and coolant levels and all the usual suspects.
Old 10-12-07, 02:00 PM   #5
CB1ROCKET
You will need to run the display diagnosis(sp?) to find out the problem, along with the following code.
Someone will be able to point you in the right direction.
However see the workshop manual on this site for more info.
Old 10-12-07, 02:14 PM   #6
dickis01
You say it's an 05 bike, with only 513 miles thats very low. I have only had my K7 for just over 2 weeks and I am only 50 miles behind you. Could it be it has had a new display incorrectley fitted. CB1ROCKET is right best thing to do is run diag on display.
Old 10-12-07, 04:55 PM   #7
tomjones2
Wise words
Old 10-12-07, 05:39 PM   #8
Goonermadness
When I first got my '05 SVS, it did exactly the same thing. Worried, I looked up on the interweb and found that it's a common/generic fault on the models of that year at startup. After a few weeks of running every day, it dissappeared and I've not seen the message since August now. And the bike has run faultlessly for 3000 miles - and been serviced since with no issues.
Old 10-12-07, 08:39 PM   #9
sv-robo
have you had the bike exorcised,as there seems to be an apperition of a man in your clocks
Using "Pointy" Tensioners in a "Curvy"? dtr125 SV Talk, Tuning & Tweaking 25 05-02-09 05:42 PM
"Chec" messege, won't start, clicks edsurf2004 SV Talk, Tuning & Tweaking 16 09-07-08 03:34 PM
Rideout "Sections" or "Groups" independentphoto Bikes - Talk & Issues 19 04-09-07 01:08 PM
Bike running very "lumpy" when top speed is reache SpankyHam SV Talk, Tuning & Tweaking 9 03-05-06 06:26 AM
