Old 03-02-08, 12:09 PM   #1
Jester666
Question Help!! Am I being stoopid?
Anyone know how to remove the spring from an SRAD GSXR 750 rear shock?
Any help is most welcome.
Old 03-02-08, 12:16 PM   #2
Stig
Default Re: Help!! Am I being stoopid?
Hacksaw
Old 03-02-08, 12:22 PM   #3
Jester666
Thought of that but I need the rest of the shock to put the SV spring back on!
Old 03-02-08, 12:25 PM   #4
Stig
Don't you need a special tool to take these apart
Old 03-02-08, 12:29 PM   #5
Jester666
I've got spring compressors but does the shock unscrew/dismantle from the top or bottom.
Old 03-02-08, 06:05 PM   #6
Flamin_Squirrel
You shouldn't need a spring compressor. You should be able dismantle the shock at the bottom.
Slacken the preload rings right off to take all the load off the spring. That should allow you to push up on the disc that the spring sits on at the bottom of the shock and slide it out, to allow you to remove the spring.
This is true for later GSXR Shocks anyway, should be the same for yours.
Old 03-02-08, 11:53 PM   #7
Jester666
Cool. Cheers FS!
Silverline Impact Drive (Stoopid question alert) Tiger 55 SV Talk, Tuning & Tweaking 11 12-03-07 03:26 PM
Some more reasons to not do stoopid things... Jdubya Idle Banter 20 17-03-06 03:31 PM
stoopid sparkplugs. Brand New SV Talk, Tuning & Tweaking 8 18-11-05 12:36 PM
Stoopid Drivers ! wheelnut SV Talk, Tuning & Tweaking 5 02-01-70 06:22 PM
