Old 04-03-08, 09:55 AM   #1
malks
Default clutch/gear box problem
hi all,
after getting the bike cleaned up and new tyres fitted ready for some better weather i've noticed a problem with gear changes.
when the bike it doesnt want to go from 1st up to neutral. it jumps 1st to 2nd. now taking the bike out on saturday this was intermitent. its not me being heavy with changes either it just jumps past neutral and goes into 2nd. now if i turn the engine off and put the ignition on (but not staring the bike) it pops perfectly from neutral down to first and then back to neutral again.
could the lever just be stiff after sitting for most of winter? could something need adjusted? if so would i be able to fix it myself or best to go to a garage?? oh and its an '06 pointy! with just aout 5k on the clock
Old 04-03-08, 01:45 PM   #2
richard_1069
Default Re: clutch/gear box problem
Hi,
I had this problem with mine and I found making a small adjustment with the clutch fixed the problem for me, hth
Richard
Old 04-03-08, 10:02 PM   #3
Search my name and clutch adjustment.
Old 05-03-08, 11:45 AM   #4
embee
embee's Avatar
That sounds almost biblical!
Old 05-03-08, 12:07 PM   #5
Lol all hail the prophet sid.
Maybe an oil change would be a good idea, since it's been stood over winter. (you poof )
Old 05-03-08, 02:40 PM   #6
malks
it was serviced just before going into the shed. me thinks time i got some spanners and had a go myself!!!
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Gear/Clutch problem on new SV Dee4Life SV Talk, Tuning & Tweaking 7 06-12-06 11:52 AM
