Old 05-03-08, 07:42 PM   #1
kd sweety
Default Worlds stupidest question - how do I get the front seat off?
As the title says, how do i get the front seat off my K3? I know the rear comes off from the lock but I just cant find how the front comes off! Can anyone enlighten me on the soon to be obvious answer? Ta
Old 05-03-08, 07:44 PM   #2
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: Worlds stpidest question, how do i get the fron seat off?
assuming it's the pointy in your sig you need to remove the two plastic covers about the size of your hand just below the seat, one on each side, before you can access the seat screws
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 05-03-08, 07:44 PM   #3
BoltonSte
Assuming it's the same as the curvy, remove the little black side panels (take out the bolt and then swing back) this exposes the bolts that hold the seat.
HTH
Ste
Beaten to it.
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 05-03-08, 07:47 PM   #4
DoubleD
Just below the front seat on the sides there is a triangle bit of plastic held on with a allen bolt. Remove these plastic triangle bits.
Under them you will see another allen bolt on each side (bigger one this time) remove these bolts.
Now the seat will come off, grip the seat at the front and lift up, the back of the seat is hooked in and will just slide out.
HTH
EDIT: must type faster and what they said.
Old 05-03-08, 07:48 PM   #5
kd sweety
oh poo, i had them both off and i must have missed them! i would have thought they would have mad eit alot easier to get to, even the italians made the seat easy to get off, although they did stick everything under the tank
Old 06-03-08, 12:19 AM   #6
maultin
i had exactly the same problem on my curvy when i 1st got it.
it is stupid IMO that you cany get under the seat easier
Old 06-03-08, 07:05 AM   #7
Troy
And don't overtighten the bolts when you put them back in, causing them to strip out the threads in the fairly soft aluminum... Not that I did that, or anything!
Old 06-03-08, 08:44 AM   #8
petevtwin650
Bagster make a seat that is one piece. So you just unlock it using the key and lift it off exposing the battery compartment.
Old 06-03-08, 12:24 PM   #9
Ceri JC
...And the plastic covers will crack even easier. As I found out when I foolishly allowed a friend I was showing how to service a bike to "tighten something up".
Old 06-03-08, 12:28 PM   #10
petevtwin650
Yeah, they've got clever shouldered bolts which means you can't damage the plastics but if you don't correctly locate them in the hole then panel damage can ensue.
I'm always doubly careful with my chromed ones.
Stupidest thing you have done today? Mgaffz Idle Banter 38 06-04-09 02:51 PM
Quick car seat question Messie Idle Banter 5 18-06-08 01:25 AM
Seat question... Baph SV Talk, Tuning & Tweaking 3 23-08-06 12:11 PM
seat cowl, k4 question hall13uk Idle Banter 20 04-02-06 04:38 PM
SV650 seat question Bagpuss SV Talk, Tuning & Tweaking 1 23-09-04 03:13 PM
