Old 10-03-08, 08:51 PM   #1
wyrdness
Default Bad wind & blowing off
I've got this problem with wind. The cover on my bike keeps blowing off and I'm getting tired of finding the bike uncovered every morning. It's only a cheap Lidl cover and it getting a bit tatty. So I'm looking to replace it with something a bit better. Any recommendations for covers that won't
blow away during the night? The Oxford Stormex looks good, but's a bit pricy at £60 (from Infinity). Is it worth the dosh?
Old 10-03-08, 09:00 PM   #2
pmapp
pmapp's Avatar
Default Re: Bad wind & blowing off
Before I got my Bike Safe I used a cover at home. It didn't have any form of fastening on it.
I ran gaffa tape along the bottom of it, then punched holes in it (gaffa was to try and stop it ripping - which it did). I then used bungee straps throung the holes, round pegs etc to secure it. I never lost it after that
Old 10-03-08, 09:46 PM   #3
Davido
Old 10-03-08, 10:41 PM   #4
Dicky Ticker
If the wind is enough to blow the cover off it is enough to blow the bike over. I would be leaving the cover off in extremely windy conditions,might be wet but still in one piece.
Old 10-03-08, 10:48 PM   #5
muzikill
muzikill's Avatar
Clothes line, the cheapy plastic stuff - works a treat to tie it with. ive got the cheap lidl cover and theres nowt wrong with it, my cousing bought a so called expensive one (oxford, silver colored) one winter later and he takes it off only to find it had cracked and rain got into the top of the bike and the chains all rusted!
Old 10-03-08, 10:52 PM   #6
sv650k4
i got an oxford one with a bike before and it seemed very heavy duty and good tho i never used it so i couldnt really tell you weather or not they fall apart or not but like i said it seemed very good and heavy duty!
Old 10-03-08, 10:53 PM   #7
rictus01
rictus01's Avatar
Oxford stormex, bit pricy, but a click strap goes under the bike and a lot of sown eyelets to put a chain threw.
Cheers Mark.
Old 10-03-08, 10:54 PM   #8
sv650k4
i think this is the same as the one im talking about:
http://cgi.ebay.co.uk/Oxford-RAINEX-...QQcmdZViewItem
bit pricey but if they do the job well then probley worth it.
Old 10-03-08, 10:55 PM   #9
sv650k4
Cheers Mark.
just like the one i was talking about lol and the one in the link.
Old 10-03-08, 10:57 PM   #10
rictus01
rictus01's Avatar
Errr No, mine is black and looks to be heavier than that one.
Fuse keeps blowing benjyman Bikes - Talk & Issues 10 03-06-09 12:52 PM
fuse keeps blowing bobm SV Talk, Tuning & Tweaking 5 23-10-08 07:57 AM
Headlights keep blowing Stig SV Talk, Tuning & Tweaking 18 02-04-08 05:55 PM
Blowing fuses keltoi Bikes - Talk & Issues 2 08-06-07 05:57 PM
She's blowing pingu SV Talk, Tuning & Tweaking 5 11-06-06 07:09 PM
