Old 22-10-08, 10:14 AM   #1
bobm
Default fuse keeps blowing
Hi All,
I recently replaced battery and regulator/rectifier on my Suzuki SV650s.
Before putting the battery I charged it to 100% overnight.
The RR (electrix) I got is not the proper one for this bike but in Gorey Bikes they told me all RR are similar and he sold me the one I have now. The connection was similar as the original except for the two output wires which I soldered on the original connector.
Anyway when I ran the engine (revs 5K) I checked the output voltage to be 14-15V. Seemed ok but a bit on the high side.
Then 15A fuse of the Meter circuit blew. I checked for any obvious shorts but couldn't find any. I put in a 20A fuse but it blew also after I revved the engine.
I thought maybe the RR lets spikes through if the battery is fully charged.
As I was running out of fuses and needed the bike the next morning I disconnected the RR and put in my last fuse.
With a disconnected RR it also blew the fuse!
Anyway I call up Gorey Bikes and he said stop off at the shop on your way passing and we check it out for you. I did that and they told me everything was alright (charged 20 to replace fuses). After that the fuse didn't blow for a few days riding. But just yesterday after the end of my 60mile commute the 'Meter' fuse blew again.
What can I do to diagnose the problem? Today I noticed that when battery is 100% at end of ride the bike lights become much brighter when revving the engine. The ODO meter goes funny 88888 a few seconds when revving.
Thanks for any help,
Bob
Old 22-10-08, 03:25 PM   #2
branny
Default Re: fuse keeps blowing
This is often very useful for electrical problems-
http://www.thegsresources.com/garage/gs_statorfault.htm
Old 22-10-08, 03:28 PM   #3
Lights going funny when revving points back to the RR again.
Old 22-10-08, 03:33 PM   #4
bobm
Thanks lads,
I'll check tonite.
Old 22-10-08, 06:47 PM   #5
embee
embee's Avatar
You don't say what year, but if it's a curvey there are a number of known points where the wiring harness can chafe through, causing various running/fuse blowing problems.
Key points are behind each of the rider seat fixing bolts, also under the pillion seat where the harness bends round a frame bracket (left side towards the rear), and also generally round the headstock area where it flexes when turning the bars.
Old 23-10-08, 07:57 AM   #6
bobm
It is a curvy and I will check the wiring as you suggested.
Thanks
Fuse keeps blowing benjyman Bikes - Talk & Issues 10 03-06-09 12:52 PM
Ignition Fuse blowing Frogman SV Talk, Tuning & Tweaking 7 16-04-07 05:57 PM
ignition fuse keeps blowing any ideas adey SV Talk, Tuning & Tweaking 6 06-06-06 04:22 PM
Main fuse keeps blowing JMCHITTOCK SV Talk, Tuning & Tweaking 7 09-09-05 11:17 AM
HELP...keep blowing a fuse jessie SV Talk, Tuning & Tweaking 5 24-03-05 10:01 PM
