Old 24-03-05, 08:46 AM   #1
jessie
Default HELP...keep blowing a fuse
There seems to be a problem with my flashers…
The right hand flashers occasionally seem to trigger my Instrument Fuse to blow.
The flashers on the LH work ok, every now and then the RH will not work, the headlights dim and then the fuse blows.
Am thinking that its either the Flasher Switch, the flasher unit or a dead short somewhere within the wiring?
Anyone else had this problem?
any hints?
where is flasher unit (if it exists??) on bike?
j
Old 24-03-05, 08:59 AM   #2
454697819
Hi there,
Flasher unit located underneath the seat next to the fuse box,
try a libral spray of wd40,
Other possibilities is a chaffed wire?
Faulty indicator?
Not a lot of help but a possiblt starting point.
Alex
Old 24-03-05, 11:39 AM   #3
weegaz22
check for wires chaffing under the fuse and relay area under the seat
Old 24-03-05, 07:35 PM   #4
Stig
I'd say you have a shorting wire at a guess
Old 24-03-05, 09:59 PM   #5
RandyO
I've seen bulbs short out too
Old 24-03-05, 10:01 PM   #6
Itching 2 go
also have you had to change any indicator bulbs recently? was it the same you put in to what came out?
Fuse keeps blowing benjyman Bikes - Talk & Issues 10 03-06-09 12:52 PM
fuse keeps blowing bobm SV Talk, Tuning & Tweaking 5 23-10-08 07:57 AM
Ignition Fuse blowing Frogman SV Talk, Tuning & Tweaking 7 16-04-07 05:57 PM
ignition fuse keeps blowing any ideas adey SV Talk, Tuning & Tweaking 6 06-06-06 04:22 PM
Main fuse keeps blowing JMCHITTOCK SV Talk, Tuning & Tweaking 7 09-09-05 11:17 AM
