Old 19-04-08, 09:00 AM   #1
weazelz
Default MoT requirements
currently putting my bike back together for an MoT, do I need:
- [front] indicators
- horn
thanks
Old 19-04-08, 09:12 AM   #2
shifter
Default Re: MoT requirements
As far as the horn goes I'm sure you do.
As for indicators I'm not sure, it could be a case of if they are fitted they must work, or bikes after a certain year must have them.
You could always phone the mot place and ask?
Old 19-04-08, 09:48 AM   #3
sv650k4
the horn i think you defo need but as for indicators im not 2 sure.
i no you dont need them for a day time MOT.
Old 19-04-08, 11:12 AM   #4
derbybiker
Have a look at this >>> link <<< for your indicators
and this >>> link <<< for your horn
Old 19-04-08, 11:27 AM   #5
Dangerous Dave
Yes for a horn and for the indicators if they are fitted then yes they need to work, fitted also means having the switch on the left switch gear fitted too.
Old 19-04-08, 12:29 PM   #6
embee
embee's Avatar
Indicators - it's slightly more involved, but from what I remember the simple guide is that if it's a modern bike with any lights, and had indicators fitted at the date of original registration then it should have them fitted and working.
(I haven't checked with the regs/rules, but that's effectively what I remember it to be......... )
Old 19-04-08, 02:03 PM   #7
weazelz
okay, thanks. sounds like I'd better sort the indicators & re-wire my lap-timer
Old 19-04-08, 05:12 PM   #8
richwill68
Horn is a definate.
Indicators- if fitted must work. If you remove them, you must also remove the switch. Just take the switch gear appart, remove the arm that works the switch (so no bits stick out), replace switchgear then put black insulating tape over the slot left behind.
Regards
Rich
Old 19-04-08, 06:12 PM   #9
petevtwin650
Horn? Doesn't that mean just an audible warning device. I believe, although never tried it myself, that a bicycle bulb type horn or bell will suffice.
Old 19-04-08, 06:25 PM   #10
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
while we're on topic, are wing mirrors an MOT requirement?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Visa Requirements SoulKiss SV Ecosse 9 02-04-07 06:55 PM
MOT Requirements Mr UKI Bikes - Talk & Issues 5 16-07-06 12:06 PM
daylight MOT requirements mr&mrs_sv Bikes - Talk & Issues 12 22-03-06 12:28 AM
My BBQ - Dietary requirements? MattTheLoony TOTALSV Ireland 8 13-07-05 09:12 PM
