Old 23-04-08, 09:09 PM   #1
flymo
flymo's Avatar
Default PAIR modification
Hi all, sorry to drag this thread from the distant past but I have a question.
I was reading the thread by Chewy (is he still around here by the way?) - http://forums.sv650.org/showthread.php?t=56239 where it discusses removing the pair system etc. No problems with the description except that it mentions the use of a resistor. I presume that resistor is to join the two wires from the ECU that run to the PAIR solenoid but it doesnt say this and also doesnt mention the value of resistor required.
Can anybody shed any light on this for me? ta.
Old 23-04-08, 09:57 PM   #2
flymo
flymo's Avatar
Default Re: PAIR modification
I've since found this elsewhere.....
To avoid having an FI fault on the display and ERROR (C49) you will need to wire in the 10K OHM resistor in place of the PAIR pump. This will fool ECU into thinking the pump is still there and functioning properly.
....so think I've answered my own question.
Old 23-04-08, 10:07 PM   #3
markmoto
you going to make some square blanking plates for the rocker covers mike?
Old 23-04-08, 10:13 PM   #4
flymo
flymo's Avatar
Yeah, either that or buy some. I see Chewy sells them as a set for £15 here http://www.chewys-stuff.co.uk/pair_r...650k3_pair.htm
Old 23-04-08, 10:15 PM   #5
markmoto
Kool not seen them, i quite liked the popping on overun when i had my sv whats the advantages of removing it? just save abit of weight and tidy it up abit?
Old 23-04-08, 10:22 PM   #6
flymo
flymo's Avatar
to be honest the main reason we tried to disable this this evening was to try and get sensible readings on my mates dyno. When the PAIR system is sucking fresh air into the exhaust chamber it gives false lean readings.
So then got to thinking what possible purpose it has on a race bike, none is my guess. So for a pretty simple mod you can simply get rid of it. Chewy suggests keeping the reed valves in place as they have a gasket built in, but then covering the gap over with these plates, blocking off the airbox hole left by the PAIR solenoid and then putting a 10K resistor across the wires to the ECU.
Old 23-04-08, 10:25 PM   #7
Can you just block the air feed to it?
Old 23-04-08, 10:26 PM   #8
markmoto
Ahh rite yeah of course it would do yeah! like you say it has no place on a racebike. What sort of power where you getting on the dyno mike?
Old 23-04-08, 10:27 PM   #9
markmoto
Yeah you can do mate.
Old 23-04-08, 10:31 PM   #10
flymo
flymo's Avatar
Blocking off the tubes does pretty much the same thing, removing it simply tidies everything up nicely.
We didnt do any fuelling optimisation due to the sensor problem we had on the dyno but its currently giving 73bhp at the rear wheel so not bad really. Pretty strong motor. Torque was impressive too.
Its modification time! Tell SV Talk, Tuning & Tweaking 10 01-12-07 04:46 PM
SV650S K4 AIR BOX Modification peterjohnwood SV Talk, Tuning & Tweaking 9 26-04-06 09:44 PM
modification medwaysv SV Talk, Tuning & Tweaking 14 18-02-06 09:20 AM
Fairing Modification sprocket SV Talk, Tuning & Tweaking 0 03-05-05 11:35 PM
Best Modification per £ chris SVK3 SV Talk, Tuning & Tweaking 21 16-01-05 01:21 PM
