I picked up one of these from the local shop the other day...
http://www.motrax.co.uk/index.php?pa...roduct_id=1639 ... it thought it was worth a go as it was only a tenner and bleeding the brakes is a really tedious job. It's bleeding marvellous ![]() |
A mate of mine uses one and really rates it.
Got one and it makes bleeding soooo simple.
Fantastic wee gadget! Needs a longer tube though...
What exactly is it?
It's basically a one-way check valve. Has a little arrow marked on the body to show which direction fluid goes through it. You fit it to the bleed nipple, release the bleed nipple, then just pump the brake lever. The gadget has a spring loaded ball or similar inside with the spring pushing it against a sealing face against the direction of flow. So when you pump the lever the fluid forces the ball against the spring and allows fluid to flow out, but as soon as you release the lever the ball is pushed back against the sealing face in the gadget and prevents fluid/air being drawn back in to the calliper. Just pump away until all the air/old fluid is out the calliper and then tighten up the bleed nipple. Job done.
wow, I want one
#9 |
thats something the sam as the one i have mine is a we sealy one works the very best and makes the job alot easyer than wot is normally is!
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads | sv-racing-parts | SV Talk, Tuning & Tweaking | 42 | 15-09-11 10:27 PM |
GT Moto Brake Bleeder | Luckypants | Ancillaries | 10 | 18-07-11 11:29 AM |
Brake Bleed nipple/Mityvac/Brake Fluid query | Ceri JC | SV Talk, Tuning & Tweaking | 15 | 20-01-09 02:04 PM |
Front brake not activating brake light properly | SVeeedy Gonzales | SV Talk, Tuning & Tweaking | 5 | 27-02-07 12:09 PM |
Stuck master cylinder bleeder | northwind | SV Talk, Tuning & Tweaking | 0 | 28-06-06 09:27 PM |
