Old 08-05-08, 06:42 PM   #1
evertheoptimist
Default non starter
my bike wont start red light comes on, lights are working battery is ok anyone got any ideas
Old 08-05-08, 06:48 PM   #2
pencil shavings
Default Re: non starter
kill switch?
Old 08-05-08, 06:54 PM   #3
evertheoptimist
thanks its not that
Old 08-05-08, 06:55 PM   #4
pencil shavings
does it turn over?
Old 08-05-08, 07:31 PM   #5
NedSVS
If it will not turn over on the starter but will bump start, the it is almost certainly the safety switch on the clutch lever. Ideally, remove the switch with a phillips number 1 srewdriver (easier if you slacken the lever clamp and rotate it to upside down) and give it a good flush out with WD40. If you have a multimeter, or continuity tester, you can check the contacts are closed when the clutch is pulled in.
Old 08-05-08, 07:47 PM   #6
sv650k4
aye its proley one of the safty switchs.your better doing away with them.
Old 08-05-08, 07:59 PM   #7
Baph
I disagree on the latter part of that. Granted the clutch switch can be annoying, but I'd rather have it than leave the sidestand down & ride.
As for the OP, a little more detail as to what the bike is/isn't doing would be helpful. Could be the switch, could be one of the fuses, could be HT cables or pretty much any other bit of wiring.
Old 08-05-08, 08:29 PM   #8
evertheoptimist
Hi thanks for the replies it was the wire that connects under the clutch lever that had come off , must have come off when I washed the bike so one to watch out for in the future. Thanks again.
Old 08-05-08, 11:39 PM   #9
Moral of the story, don't wash your bike.
Old 09-05-08, 06:19 AM   #10
Mr_Chin
OMG, Kwak did you just hear what Yorkie said???
It's ON.... I'll get my coat!!!
Chin
Non starter. AndyBrad SV Talk, Tuning & Tweaking 61 26-05-09 07:50 PM
non starter richiekuk SV Talk, Tuning & Tweaking 41 22-05-09 01:49 PM
Non Starter slloyd SV Talk, Tuning & Tweaking 3 01-03-09 03:11 PM
Non-starter for ten... Bluewolf SV Talk, Tuning & Tweaking 6 23-08-07 09:21 AM
Non starter - help sticky-dizzle SV Talk, Tuning & Tweaking 11 12-04-07 02:38 AM
