Old 28-02-09, 05:30 PM   #1
slloyd
Default Non Starter
Anyone come across this where the bike stalls, and when you go to restart there is no life from the ignition and most electrics are dead. lights work and horn, but starter fails to ignite.
Only after a quick jump start then everything comes to life.
I have removed the battery and using a Dr Bike Optimiser and I have 3 lights lit - the red, orange and yellow light which means the battery is between 6-12volts.
Should this not be enough? I find it very weird that the bike has no kick after stalling.
I've made sure when restarting the bike is in neutral, and the clutch level is pulled in when the ignition is switched.
It's fine, if I turn the bike on/off through normal operating.
advice please, while I keep the battery on charge.
Old 28-02-09, 05:49 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Non Starter
No thats not enough to start an SV.Fully charge the battery then test it to see what its like.Worth buying a cheap multimeter to test the whole charging system if its playing up.
Old 28-02-09, 06:06 PM   #3
slloyd
Bike Biggles...thanks for that advice, will keep the battery on charge til the morning and refit and give it another ride out - "With AA Card in my Wallet, just in case" will keep the post updated to see what happens.
Old 01-03-09, 03:11 PM   #4
slloyd
Just taken the curvy out for a quick spin, and all seems ok after the battery been on charge overnight...stalled a few times, and restarted ok.
Will keep a eye on things and see what gives...thanks all.
Non starter. AndyBrad SV Talk, Tuning & Tweaking 61 26-05-09 07:50 PM
non starter richiekuk SV Talk, Tuning & Tweaking 41 22-05-09 01:49 PM
non starter evertheoptimist SV Talk, Tuning & Tweaking 9 09-05-08 06:19 AM
Non-starter for ten... Bluewolf SV Talk, Tuning & Tweaking 6 23-08-07 09:21 AM
Non starter - help sticky-dizzle SV Talk, Tuning & Tweaking 11 12-04-07 02:38 AM
