Old 24-05-08, 10:08 PM   #1
Binky
Emily Howard rides an SV
Binky's Avatar
Default Speedo Broken
Just wondered if anyone could tell me why this is and what i need to do to get it working again???
I am a guy with limited mechanical ability so will i have to take it to a garage or anything? How much would this cost??? etc
Wowee Zowee
Old 24-05-08, 10:10 PM   #2
plowsie
Default Re: Speedo Broken
Some piccys may be a good idea where it is all connected up.
Old 24-05-08, 10:30 PM   #3
Binky
Binky's Avatar
Ok, i'll try and take some asap.
Wowee Zowee
Old 24-05-08, 10:32 PM   #4
plowsie
When you say broken, is it working to a certain speed or just not at all?
Old 24-05-08, 10:35 PM   #5
simesb
Primary cause of the speedo not working appears to be the rotor at the front wheel. Take the wheel off, and if lots of bits of brown plastic fall out, you need to buy a new one....
Old 24-05-08, 10:41 PM   #6
Binky
Binky's Avatar
No, it just stays on zero no matter how fast i am going...
Wowee Zowee
Old 24-05-08, 10:42 PM   #7
plowsie
Hve you got a torque wrench - this is for simesb's tip.
Old 24-05-08, 10:45 PM   #8
simesb
And a large hex socket for the axle bolt.
Old 24-05-08, 10:51 PM   #9
Ian1971
Mines just started doing this too at one point it was reading 148mph then 0 mph sometimes it moves from 0 up to 8mph then just back to 0
Old 24-05-08, 10:54 PM   #10
simesb
random readings as the rotor disintegrates appear to be quite common. 34983-21E00 is the part number for the rotor (at least on a pointy)
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
Speedo accuracy. If your '99 650 is showing 37mph on the speedo. lloyd_christmas SV Talk, Tuning & Tweaking 14 12-06-08 12:02 PM
Speedo broken Warthog SV Talk, Tuning & Tweaking 6 19-03-08 04:17 PM
Broken dreams and broken lives. Peter Henry Idle Banter 7 15-09-06 07:43 AM
Is my speedo cable broken ? fizzwheel SV Talk, Tuning & Tweaking 14 30-11-05 10:30 AM
