Old 28-11-05, 01:37 PM   #1
fizzwheel
fizzwheel's Avatar
Default Is my speedo cable broken ?
Got on bike earlier on, noticed that the speedo needle wasnt registering.
Sometimes it moves justs a little it'll wobble up to about 10mph and the drop back down again.
I had a new speedo drive a while ago and the symptoms are similar, but there isnt the constant clicking / squealing noise that I had when the speedo drive failed before.
I think therefore that the speedo cable is broken.
Thoughts....
Thanks
Fizz
Old 28-11-05, 01:48 PM   #2
Check the speedo drive, if you've had a simialr problem before it's the obvious place to start.
Cable wise it could be damaged such that it makes intemittent contact, check where the cable runs past the lockstops - a common area for the cable to get trapped - if it's been pinched a bit and is either shorting or making poor contact it might explain your problem.
Old 28-11-05, 02:34 PM   #3
Viney
See, the blue flame can has made ya speedo pack up now
Old 28-11-05, 02:37 PM   #4
fizzwheel
fizzwheel's Avatar
I think the vibrations from it have made the rest of the bike pack up in sympathy
*i've got the standard can on it at the moment
Old 28-11-05, 08:06 PM   #5
A bad battery connection, or connection to the clocks, could do that as well... But the number one suspect would be the wee rotor in the speedo drive.
Old 29-11-05, 08:51 AM   #6
Grinch
Mine got caought behind my stop locks and the cable was pinched, so I would get the needle jumping around all over the place. I just dropped it out, cut, rewired and taped it up... Its a bit fatter there now but works just fine.
Old 29-11-05, 01:07 PM   #7
GSXR Carlos
which model?
my curvey 2001 s had trouble, turned out to be a wierd thing in the front wheel spindle, can't remember the name of it but i got mine from a suzuki suppliers for around a tenner, this might be your problem, and is an easy fix
i'll see if i can find details
Old 29-11-05, 01:16 PM   #8
dclifford
It sounds like the drive. When mine broke there was no clicking sound.
I believe it got damaged when the mechanic replaced the front tyre. Have you had the front wheel off recently. It is very easy to break it if not paying attention to it.
Old 29-11-05, 01:34 PM   #9
fizzwheel
fizzwheel's Avatar
Its a curvey 2000 model
It had a new drive sometime last year, front wheel came out about 3000 miles ago for a new front tyre
Old 29-11-05, 01:38 PM   #10
Jase22
Might be a stupid question, but have you actually taken the cable off yet? That'll be the easiest way to see if it's busted.
Broken rad mount - will cable ties do? aarond Bikes - Talk & Issues 6 27-11-08 05:18 PM
Speedo Broken Binky SV Talk, Tuning & Tweaking 22 25-05-08 07:15 AM
Speedo broken Warthog SV Talk, Tuning & Tweaking 6 19-03-08 04:17 PM
Help! Speedo cable replacement brodie Bikes - Talk & Issues 3 12-02-07 11:11 AM
SV650 K3 speedo cable Khewett Stuff Wanted 0 01-05-06 07:24 PM
