Old 26-11-08, 08:02 PM   #1
aarond
Default Broken rad mount - will cable ties do?
Just been putting back on the radiator on a 2001 tl s and the bolt on the top of the left of the radiator has snapped in the frame when putting it in. I have tried to get it drilled out, etc just not having it so the question is would a couple of cable ties onto the bottom of the damper bracket be enough? Please help asap!
I have posted this on the tl forum too but need a very quick reply so can get it back together! are cable ties strong enough thats all it seems to hold
Old 26-11-08, 08:10 PM   #2
Dangerous Dave
Default Re: help..
Zip ties will do as a part time solution, I have doen this before, but you have make sure they are ziopped up tightly and are not the cheap thin ones.
I would advise you get a torque wrench too, those bolts snap if you over tighten them.
Old 26-11-08, 08:12 PM   #3
aarond
Default Re: help..
i was just using a tiny wrench have a torque wrench just didnt think to use it, wasnt even tightening that hard and just snapped reckon a weak bolt will use ties then until can fab up bracket from different hole. Cheers for the quick reply
Old 26-11-08, 08:13 PM   #4
Dangerous Dave
Default Re: help..
No probs mate
Old 26-11-08, 08:43 PM   #5
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: help..
not wishing to high jack, but does anyone know the top 2 bolt size?, i've lost mine
05 DRZ400E
RIP hovis
Old 27-11-08, 08:22 AM   #6
Dangerous Dave
Default Re: help..
The top two bolts which hold the radiator on, for an SV, are M6 x 25mm.
Old 27-11-08, 05:18 PM   #7
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: help..
tar mate
05 DRZ400E
RIP hovis
Broken mount point, what to do drag Bikes - Talk & Issues 31 27-08-08 06:33 PM
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
Ram Mount Bluepete Photos 13 12-06-07 12:33 PM
Broken dreams and broken lives. Peter Henry Idle Banter 7 15-09-06 07:43 AM
Is my speedo cable broken ? fizzwheel SV Talk, Tuning & Tweaking 14 30-11-05 10:30 AM
