Old 11-02-07, 01:57 PM   #1
brodie
Default Help! Speedo cable replacement
Hi All,
My speedo has ceased to work and i've tracked the problem back to the cable. It went in for repair a while ago and i guess the didn't secure it with cable clips well enough as it's now become squashed between the steering stem and handlebars.
Do i need to replace the whole sensor or can i just replace the cable? I have an SV650S K4, the cable leads from the front left wheel into the tank, and then i guess comes back out the same place into the cowl, is this right?
Also, where's the best/cheapest place to buy replacements or is something like this best left to a garage? I'm pretty novice but fitted my own exhaust full-system and can tinker happily
Thanks in advance,
Brodie
Old 11-02-07, 03:07 PM   #2
Just cut the damaged section from the wire and reconnect, it'll most likely be fine, if it isn't you've lost nothing finding out.
Old 11-02-07, 05:12 PM   #3
Mariner
I'm sure I have a cable/sender unit from an older curvy SV, it doesn't have the rotator bit, but if it fits you can have it for a reasonable price.
Old 12-02-07, 11:11 AM   #4
brodie
Cheers Sid,
A good idea, although not sure i can as its in a pretty tight spot and seems like its got a few wires in it? You can see where its caught between the stopper and stem, guess the garage didn't clip it when they repaired it.
Thanks Mariner i'll see how much the new set me back and if its a whack i'll be in touch.
Brodie
Speedo cable - Beg Steal or Borrow seedy100 Stuff Wanted 10 16-05-08 04:28 PM
Speedo sensor and cable Warthog Stuff Wanted 1 04-05-08 10:02 PM
Clutch Cable replacement. dmracing SV Talk, Tuning & Tweaking 1 21-10-07 11:45 AM
SV650 K3 speedo cable Khewett Stuff Wanted 0 01-05-06 07:24 PM
Is my speedo cable broken ? fizzwheel SV Talk, Tuning & Tweaking 14 30-11-05 10:30 AM
