Old 26-05-08, 07:15 AM   #1
petevtwin650
Question Woodruff Key.
Still pondering on my fuelling problem. A long while ago I fitted the 4deg woodruff key. If that has broken, could the timing slip or, does the interference fit on the tapered shaft prevent it from moving?
Old 26-05-08, 08:18 AM   #2
timwilky
timwilky's Avatar
Default Re: Woodruff Key.
In theory a woodruff key is simply a location device and does not have any load bearing responsibility. The taper fit should be all that is required to transmit a drive force. Think of the Morse tapers used for drills, milling machines lathes etc.
That said, I have in the past snapped woodruff keys but always because some cack handed so called mechanic has not tightened up pulleys etc properly.
Not Grumpy, opinionated.
Old 26-05-08, 11:12 AM   #3
Yes it could snap but only if the actual rotor bolt wasn't tight when the engines been turned over.
As timwilky said it shouldn't be able to move.
If it had shifted, I'd expect it to shift so far that it wouldn't run full stop.
Old 26-05-08, 01:03 PM   #4
If the key was damaged enough to allow the rotor to move relative to the crank then the bolt would have to be loose and the rotor detached from the taper - I'd be surprised if it ran at all.
As Tim rightly says the key is only there to locate the rotor when fitting it - it plays no part in driving the rotor once correctly fitted.
Old 26-05-08, 09:29 PM   #5
petevtwin650
Thank you gentlemen. Just another example of my mechanical ineptitude. Was hoping for an easy fix.
Old 26-05-08, 09:55 PM   #6
Ok Daz is a DIVVY time Whats a woodruff key?
Old 26-05-08, 09:58 PM   #7
petevtwin650
Silly boy Daz.
Everybody knows you use it to get into a Woodruff house.
Old 26-05-08, 10:00 PM   #8
thats just what i was thinking but was too shy to ask
Old 26-05-08, 10:03 PM   #9
petevtwin650
It's a tiny sliver of metal (No 8 in the diagram) that precisely locates the generator to the crankshaft. As I understand it.
Old 26-05-08, 10:03 PM   #10
fankoooo kind sir!
offset woodruff key install, puller tool required adam_castell SV Talk, Tuning & Tweaking 23 25-11-07 07:50 PM
offset woodruff key / ignition advance adam_castell Stuff Wanted 0 12-11-07 02:52 PM
Offset Woodruff key to advance ignition by 4° Richie SV Talk, Tuning & Tweaking 1 22-07-07 06:20 PM
