Old 26-05-08, 08:48 AM   #1
beaniebikerbabe
Default Regulator-rectifier
hiya all, any one have a rectifier or advice where is best to get one from for curvy???
thanks
Old 26-05-08, 08:53 AM   #2
Lissa
Just Ballast
Lissa's Avatar
Default Re: rec
Here I think.
http://www.electrexworld.co.uk/
RR85. About 60 quid
However thedonal bought one quite recently and had a load of fitting problems.
What year is your curvy BBB?
I got my mine from a local bike parts shop. Don't know yet if it's any good though.
Old 26-05-08, 10:13 AM   #3
Dangerous Dave
Default Re: rec
I am baffled by all this, i think there must have been a faulty Suzuki batch at some point as all my Curvy's have never had a problem and they all have the original one fitted.
Any way, as Lissa said above....
Old 26-05-08, 10:21 AM   #4
andyharding
Default Re: rec
I got mine from here. http://www.busters-accessories.co.uk/ The only differance to the original one is it is slightly thinker so you need longer bolts to fit it but thats it.
Old 26-05-08, 12:09 PM   #5
mister c
mister c's Avatar
Default Re: rec
Or you can always stick a Gixxer one on. My last curvy one went pop & someone on here said the GSXR one is a heavier duty one. You have to do a little bit of wire cutting to put the SV plug on, but I didn't have any trouble after that
Old 26-05-08, 12:17 PM   #6
Default Re: rec
There's a CBR one that fits alright too.
Old 26-05-08, 12:22 PM   #7
Biker Biggles
Biker Biggles's Avatar
Default Re: rec
Yup got a CBR 600RR one in my curvy and no probs so far.
Old 26-05-08, 01:51 PM   #8
timwilky
timwilky's Avatar
Default Re: Regulator-rectifier
I second the *onda option. OK you need to do some cutting and splicing. But £20 for a breaker CBR1000RR type etc. or £60 for a pattern. I will at least try the cheaper option first.
DD, you must have got away lucky. Most people seem to have experienced RR failure at some point in their curvy ownership. However, many run off for a new battery and then discover it was the RR after all
Not Grumpy, opinionated.
Old 26-05-08, 02:08 PM   #9
Dangerous Dave
Must be luck as I test the RR once in a while and all is by the book.
Yes the Honda option is a good way to go, I have fitted many RR to other peoples bikes (all kinds) from the link Lissa provided above also!
Old 26-05-08, 09:31 PM   #10
petevtwin650
Default Re: rec
Aye, same here, touch wood. Just recently bought a spare. Just in case.
regulator rectifier K5 Pam SV Talk, Tuning & Tweaking 2 07-02-09 08:43 PM
I need a Rectifier / Regulator. Marv Stuff Wanted 3 19-08-08 12:43 PM
Rectifier/regulator Gordon B Stuff Wanted 12 02-01-08 11:00 PM
Regulator/Rectifier? Biker Biggles SV Talk, Tuning & Tweaking 22 31-05-07 08:55 PM
K2 regulator/rectifier, new in box northwind For Sale - SV's and SV related items 0 22-02-07 09:14 PM
