Old 08-06-08, 02:59 PM   #1
John 675
Default clutch sensor
ive just tried starting the bike, i turn on the ignition.. the system primes in nuetral but wont do anything when the start button is pressed.. except for dim the lights.. i have checked the fuses which are fine.. ive cheked the imobaliser (as the machine primes it wouldnt be that because if it was the imobiliser.. it wouldnt prime at all..) i put it in gear and held the clutch in and the system then wont prime.. which leads me to believe its the clutch in sensor.. any ideas where to find/check this???
thanks in advsnce
LyleJ
Old 08-06-08, 03:01 PM   #2
Dangerous Dave
Default Re: clutch sensor!!
Check under the clutch lever first to make sure it isn't the connector which has dropped out.
Old 08-06-08, 03:05 PM   #3
John 675
nope not that, can i have your mobile dave? and if you have time can lend me hand??
Old 08-06-08, 03:09 PM   #4
NedSVS
If it was the clutch sensor then the lights wouldn't dim when you pressed the starter button; because if the clutch switch wasn't working then when you press the button you aren't applying power to anything. I suspect a low battery voltage or duff battery - enough to prime but not turn the starter.
Old 08-06-08, 03:20 PM   #5
John 675
yeah maybe.. although i charged overnight with an optimate??
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
speedo sensor husky03 Stuff Wanted 6 08-08-07 10:13 PM
Speed Sensor for a K3. creamerybutter Stuff Wanted 0 26-02-07 10:34 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
