Old 12-06-08, 09:49 AM   #1
DoubleD
Default Do I need to lube up??
When fitting NEW clutch cables / accelarator cables do you have to lube them up first.
By lube I mean pull a few drops of oil down the cable or will this just attract dust and crap to stick to the lube and make the cable wear out quicker then if I had done nothing and fitted the cable without lube.
Thank you 'O' mighty org
Old 12-06-08, 10:23 AM   #2
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default Re: Do I need to lube up??
I did mate when I put the new clutch and throttle cables on the cat, I put a couple of drops in the top and pulled the cable back and forward a few times to get the oil down the sleeve.
And in reponse to the thread title..
ALWAYS.. ; )
How to amuze an idiot:
Look right-> <-Look Left
Old 12-06-08, 10:52 AM   #3
Reckless Rat
Pull the cables across a candle a couple of times - gives a nice slippy wax coat that doesn't attract too much grit!
RR
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
which lube? krhall Bikes - Talk & Issues 39 02-10-08 07:00 AM
Wax or Lube?? Morpheus Bikes - Talk & Issues 26 18-03-05 06:55 PM
What lube do you use? chutz SV Talk, Tuning & Tweaking 26 09-03-04 01:37 PM
Wax or Lube?? chewy22 SV Talk, Tuning & Tweaking 23 04-01-70 03:38 AM
