Old 29-09-08, 06:59 AM   #1
krhall
Default which lube?
I know this has been posted a few times, but things change and new products come to market.
Yesterday I lubed the bike with Holts Universal Chain Lube (green snotty stuff apparently anti-fling), but rather than spary it I applied it with a brush. Chain looked nice and well lubed, because I brushed it on I was hoping to avoid chain fling..............how wrong could I have been.
The bike I spent hours cleaning yesterday is now covered in slimy gunk.
So is there a better non-fling lube or should I just put up and shut up, it is a commuter after all so the chain being lubed is the most important thing?
Old 29-09-08, 07:11 AM   #2
Dangerous Dave
Default Re: which lube?
I use scottoiler oil, I don't have a scottoiler I just buy the refills.
Old 29-09-08, 07:58 AM   #3
krhall
I had a scott oiler on the SV and it worked a treat, but there is nowhere to mount it on the new ride.
How often do you apply it DD?
Hows the recovery fella?
Old 29-09-08, 08:29 AM   #4
fizzwheel
fizzwheel's Avatar
Wurth Dry Lube. We use it on Liz's Duke as it doesnt have a Scotoiler. Doenst fling hardly at all. Give it a try.
Just remember to give the can a good shake before you spray it on the chain.
Old 29-09-08, 08:42 AM   #5
G
I use PJ1.
This stuff is super sticky, if you get it on your hands you can feel just how sticky it is.
I apply quite alot of it as I'm over cautious with chains after my friends snapped nearlly killing him. I get next to no fling at all.
Brilliant stuff and can recommend it.
6.67300 × 10-11 m3 kg-1 s-2
Old 29-09-08, 08:53 AM   #6
krhall
Which chain do I have though o ring? or non-o ring?
Old 29-09-08, 09:07 AM   #7
G
PJ1 Blue label....
Old 29-09-08, 09:38 AM   #8
jumjum_0214
I use Wurth chain lube and get absolutely zero fling!!!!!!!
Old 29-09-08, 09:40 AM   #9
G
All bike chains have Orings as far as I'm aware, there would be no point in lubing otherwise
Old 29-09-08, 10:14 AM   #10
krhall
http://www.bandcexpress.co.uk/cgi-bi....pl?cat=PJ-LUB
Look!
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
Do I need to lube up?? DoubleD SV Talk, Tuning & Tweaking 2 12-06-08 10:52 AM
Wax or Lube?? Morpheus Bikes - Talk & Issues 26 18-03-05 06:55 PM
What lube do you use? chutz SV Talk, Tuning & Tweaking 26 09-03-04 01:37 PM
Wax or Lube?? chewy22 SV Talk, Tuning & Tweaking 23 04-01-70 03:38 AM
