Old 25-06-08, 09:51 PM   #1
carsounds_dan
Default GSXR front end
Hi,
I've got hold of a GSXR750 SRAD top and bottom yolk which I payed the grand total of nothing for today. I need to get some forks and bits obviously but I think I've worked that out, it's just the bearing that I don't get.. Does anyone have the bearings individual bearing code? I have a really good bearing shop near me that I can order a bearing in for next to nothing so thought it would be cheaper than getting one from the states.
Also what forks/wheel/brakes combinations will work for a curvy with the GSXR SRAD yolks?
Also how much is the sv wheel worth, and the forks with KTECH springs?
Chees
Dan
Old 25-06-08, 09:55 PM   #2
Dangerous Dave
Default Re: GSXR front end
Its not an OEM part for any other motorbike, its custom made to spec and available from Twin Works Factory in the US.
Old 25-06-08, 09:56 PM   #3
sv650k4
an sv rim and forks would probley get about £250 ish give or take a bit plus would depend on condition etc...
Old 25-06-08, 09:56 PM   #4
carsounds_dan
yeh but it must have a bearing part number unless they generate it in house which I doubt, it'll have a small number stamped into one of it's sides
Old 25-06-08, 09:58 PM   #5
carsounds_dan
the wheel is pretty mint, has good disks, the calipers are clean with meat on the pads, the forks are ok with polished lowers but I get the feeling theyre a little bent.
Old 25-06-08, 09:59 PM   #6
Dangerous Dave
Its manufactured for them and for them only, any other place selling them has got them from them. The one I have in the 750 has no stamp and the spare I have is stamp free also!
Old 25-06-08, 11:10 PM   #7
carsounds_dan
fair enough, thought it was a standard fairing that they'd managed to work out as the job for them. if it was I could get it stuck on the back of a bearing order and get one for only a few quid.
Old 25-06-08, 11:20 PM   #8
sv650k4
a ryt will with discs you will get a bit more for the wheel compaired 2 selling it as a bare rim set of calipers with good pads you will probls get about £50-60 quid ish if the forks are bent then you probley wont get alot for them then!
Old 25-06-08, 11:21 PM   #9
sv650k4
but if your gona do the front end swap anyway you will also get money for your yokes,mud guard and clip ons etc...aswell as money for the other parts you have said.
Old 25-06-08, 11:29 PM   #10
carsounds_dan
good point.. I'll do some costing up with it all and see what happens.
Dan
Just another Gsxr front end!! :) Whitehouse SV Talk, Tuning & Tweaking 41 25-04-09 11:46 AM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
GSXR front end swap - front tyre profile. Khewett SV Talk, Tuning & Tweaking 12 11-05-06 11:24 AM
