i bought a set of renthal sprockets (standard size) and tsubaki x ring chain for my 04 sv650s. however the when i spin the back wheel the chain makes a clunking sound from around the front sprocket. i thought wheel alignment might be out but it keeps doing it when i alter alignment. i have also set it at 25- 30 mm of tension so it cant be too tight. however when i lift the bike onto its sidetand to take weight off swingarm and spin wheel it doesnt make cluncking noise.
can anyone help? |
Tension set with the bike on the sidestand?
i had it on a padock stand
set the tension with the bike on its side stand, just to be sure. Is it properly lubed?
Also check for stiff links.
Check the alignment too.
i had same problem its fine once its warn in i have your exact set up on my curvey.
#9 |
i have loosened the chain slightly. rode it for about 50 miles and when i got back and pushed the bike i couldnt here it. hopefully it is just the chain breaking in.
thanks anyway guys. |
#10 |
Keep it lubed up and double check that it isn't to slack every now and again.
Enjoy the ride... |
Clunky gear changes | Holdup | Bikes - Talk & Issues | 3 | 02-04-09 01:04 PM |
Gear change feels more clunky than usual? | krhall | SV Talk, Tuning & Tweaking | 7 | 18-03-08 05:07 PM |
Clunky Box: Reason and Remedy | dmracing | SV Talk, Tuning & Tweaking | 16 | 02-11-07 11:14 AM |
Clunky Startup.. | Daimo | SV Talk, Tuning & Tweaking | 8 | 29-01-07 03:06 PM |
clunky gears | Tomcat | SV Talk, Tuning & Tweaking | 10 | 18-08-06 08:44 AM |
