Old 12-07-08, 10:46 PM   #1
RideSV
Default Sputter at high RPMs
My bike is sputtering at higher RPMs (7,000 or so). I stored my bike with the gas tank full over the winter (a long one, Nov - May) and I think I gummed up the carburetor. So I took the air box off and sprayed the carburetor directly with carburetor cleaner. After the engine went back to idling normally (it bogged down from the carburetor cleaner) I throttled it back up and it was still sputtering at the same spot. Gummed fuel lines maybe? I'm curious what you all think. Any help is much appreciated.
~Josh
Old 13-07-08, 09:40 AM   #2
Default Re: Sputter at high RPMs
Carp in main jet or a sticky needle
Old 13-07-08, 07:05 PM   #3
RideSV
Thank you for the help. Do you think running a tank of carburetor cleaner through the system will give it a good chance of cleaning up the gunk/unsticking the jet?
Old 13-07-08, 09:28 PM   #4
Biker Biggles
Biker Biggles's Avatar
Assume its a carb model?
Have you checked the choke plungers and cables?They stick and can cause rough running.
Old 13-07-08, 10:45 PM   #5
That seems to affect low rather than high rpm, but it's worth a go.
Carb cleaner additives and so on I've not got any experience of. Worth a go perhaps.
high vis ricky Suits 8 21-01-09 10:27 AM
"Spit sputter dead" toonyank SV Talk, Tuning & Tweaking 4 17-05-07 03:19 PM
Exhaust, High level or not to high level..? Horney SV Talk, Tuning & Tweaking 5 06-10-06 03:54 PM
CCC High Level link pipe.... Bit High? bobit69 SV Talk, Tuning & Tweaking 29 13-04-06 09:16 PM
High street high side - pics added. Wiltshire7 Bikes - Talk & Issues 91 20-04-05 06:50 PM
