Old 20-08-08, 11:18 AM   #1
hovis
Default when do you change your tyres?
my rear is nearly down to the wear band in the middle, so i know its due, but last time i got it replaced, the fitter was surprised i was changing it so soon, he said most people would get another 500-1000 miles out of it.
Old 20-08-08, 11:21 AM   #2
Baph
Default Re: when do you change your tyres?
How quickly will you cover 500-1000 miles? What tyre is it? (some go off quicker than others).
Personally, I change the tyre when the grip starts going, regardless of how much tread is left.
Old 20-08-08, 11:24 AM   #3
hovis
its a michy pilot sport, it still feels good, i only got it fitted in june, (i did write down the milage when i fitted it, but cant find it)
Old 20-08-08, 11:27 AM   #4
carty
Personally I would have changed it at the point it was when we returned from the Ring trip! It's fine for dry but if you get caught in the rain you don't have a lot of water dispersal left in that tread!
Old 20-08-08, 11:36 AM   #5
timwilky
timwilky's Avatar
change it when you become concerned.
some seem to wait until it has tipped over the point where it is now a safety issue. Others when they loose confidence. you know it ain't worth the risk.
Not Grumpy, opinionated.
Old 20-08-08, 11:40 AM   #6
hovis
Originally Posted by cartwrim View Post
Personally I would have changed it at the point it was when we returned from the Ring trip! It's fine for dry !
that was the plan, as i thought it would be toast, but it was ok on the MM weekend
what would that result in? would it be ok at slow speeds, or in a straight line?
it was wet when coming home from the 80miles wostershire(?)
but it felt fine, and i kept it down to less than 100mph
Old 20-08-08, 11:43 AM   #7
ThEGr33k
When it gets a bit too flat, I do a lot of motorway miles . I run PR2's so they last ages. The rear is starting to cause the bike to fall over into corners and not flow into corners... But as long as I feel they are gripping then ill be happy. Besides I still have a tiny little bit writing to rub off the edge of the tyres...
currently my tires are on about 6K miles.
Old 20-08-08, 12:04 PM   #8
Dangerous Dave
I tend to change them whebn the rim starts to make sparks on the road...
Seriously, it is safety more than anything. Leave it too long and it could be an accident waiting to happen.
Old 20-08-08, 12:06 PM   #9
Ceri JC
In the case of rear tyres, when you can see horizontal cracks in the tyre just above the point where the mesh starts to show. In the case of front tyres, when they get so 'peaked' (opposite of squared off) that turning/handling is heavily comprimised (for me this happens quite a while before the tyre is actually worn out).
Old 20-08-08, 12:08 PM   #10
muffles
Well the tyre has to contact the tarmac rather than water, right...so when the tyre lands on the water on top of the tarmac, it has to push it somewhere so it can get through to the tarmac and grip. Part of the way it can do that is to push it into the grooves that form the tread on the tyre. I reckon with a slick tyre, what happens is that up to a point you grip just fine, as the whole tyre pushes water to the sides, past the edge of the tyre. I think there'll be a point past which you will aquaplane - and that will be aquaplaning completely, which if you had tread might not happen (only one part of the tyre might aquaplane, separated by the tread, if you have tread showing).
So I reckon you'll basically go from the grip being fine to zero grip when you have a slick. It wouldn't be progressive at all. Might be wrong though, waiting for someone to correct me
Is it possible to change tyres yourself? monkey SV Talk, Tuning & Tweaking 58 16-12-08 04:10 PM
Tyres again! New tyres to replace stock ones metalmonkey SV Talk, Tuning & Tweaking 12 01-07-08 05:48 AM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
tyres change advise rlion Tyres 4 21-02-06 03:21 PM
Oil Filter Change with every oil change? Ceri JC SV Talk, Tuning & Tweaking 2 22-11-04 06:02 PM
