Old 24-08-08, 04:04 PM   #1
instigator
Default Anyone here fitted a Givi Rack?
Hi
Bought a rack and topbox off a felow .org'er last week and I got round to fitting it this week. For those familiar with the rack and it's fitting system (on a curvey I might add), then you should recongise my poor description.
The arms went on okay, well, okay after having to drill/sand/file down a 'rogue' weld in the rectangular hollow part of the subframe so the little blocks could fit down snugly.
The rack however, I am not happy with.
There are two holes on the top of the supporting arms. On the main givi plate which goes onto these supporting arms, there is one hole and a long, rectangular hole. One set of holes match up and secure the plate initially. However, the elongated holes do not match up at all and are way off. Surely there aren't just two measly bolts that keep the plate fixed onto the arms, one on either side?
Please see badly drawn piccy.
P.S I have no camera.
Old 24-08-08, 05:18 PM   #2
littleperson
Default Re: Anyone here fitted a Givi Rack?
Originally Posted by instigator View Post
Hi
Heres a pic of mine that my other half took off
It only has 4 bolts on and he says you need to assemble the whole thing then fix to bike
Assuming you taken whole of back end of bike off to attatch as they not easy to do
There are only 2 bolts to hols plate on and 2 bolts on either side to hold arms on
Hope this helps in some way
Old 24-08-08, 05:26 PM   #3
instigator
Only the two bolts that hold on the plate, really? I've fitted one before, and think I used the same holes as you have done as shown but not this time.
Wouldn't have thought 2 bolts would be sufficient enough. Oh well, many thanks!
Old 24-08-08, 05:46 PM   #4
Dangerous Dave
PM Pete and Lissa, think they have one which they powdercoated.
Givi rack littleperson For Sale - SV's and SV related items 3 30-08-08 09:02 AM
Givi Rack his n hers sv Stuff Wanted 2 12-04-08 04:23 PM
Givi Rack sv_rory Bikes - Talk & Issues 2 03-04-08 06:47 PM
Givi rack and top box SVeeedy Gonzales Ancillaries 5 21-12-06 09:43 AM
WILL GIVI RACK FROM K4 FIT A K1? Well Oiled SV Talk, Tuning & Tweaking 2 10-06-05 09:42 PM
