Old 26-08-08, 09:09 PM   #1
pookie
pookie's Avatar
Default Disconnecting oxygen sensor on pointy
Hi, I have installed a powercommander and on some of the maps they say to disconnect the oxygen sensor. Just wondering where its located or if I need to remove it before using the map? The bike seems to run better using the stock map altho it could just be in my head.thx
Old 26-08-08, 09:16 PM   #2
Default Re: Disconnecting oxygen sensor on pointy
If you're referring to the lambda sensor it's in the exhaust pipe under the rear of the engine on the right, if you have a belly pan it may be inside that.
Old 26-08-08, 09:49 PM   #3
sv650nutter149
the sensor is only on the k7 models
Old 27-08-08, 10:49 AM   #4
From his question and sig - he's got 1000.
Which always have such sensors.
Old 27-08-08, 11:55 AM   #5
Dangerous Dave
he's got 1000.
+ 1
Old 27-08-08, 12:46 PM   #6
pookie
pookie's Avatar
cheers all..will have a look..wish i had some paddock stands now. I guess I probably have to unplug it. Now got to work out what is normal running temp.
Pointy throttle position sensor svdemon Stuff Wanted 9 02-09-08 07:50 PM
speedo sensor Apophes SV Talk, Tuning & Tweaking 2 30-01-08 09:25 AM
Speedo sensor. phil24_7 SV Talk, Tuning & Tweaking 5 19-12-07 08:41 PM
Speedo sensor phil24_7 SV Talk, Tuning & Tweaking 9 09-12-07 09:18 PM
Speed sensor, on sk1 but maybe on others too GSXR Carlos SV Talk, Tuning & Tweaking 4 13-07-05 10:36 PM
