Old 31-08-08, 05:38 PM   #1
TSM
The Sick Man
TSM's Avatar
Default Curvey Speedo LEDS
I played with some LEDs for the backlight and status lights.
Most of the status lights were ok, but the neutral light is now more of a blue/turq color than green, and the fuel amber is more of a washed out amber. The intensity of the leds with the blue tinge they give off seems to make the colours go off. So if you plan on changing these, its prolly better if you get leds of the correct color first as most of the white ones are sold as Xeon White which is bluish.
Ive yet to actualy to try the backlight at night, but the problem i can see already is that the clocks are going to be very bright around the edge of the tacho and speedo. I may play with modifying the led head to try and divert the light.
Old 31-08-08, 06:40 PM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Curvey Speedo LEDS
I had the same problem when I changed the bulbs for LEDs. For the status lights i went back to standard bulbs and changed the dial ones for green LEDs which aren't as bright as the white ones
2001 SV650 in shimmerin green, Not broken anymore
Old 31-08-08, 06:43 PM   #3
TSM
The Sick Man
TSM's Avatar
I dont mind having LEDs for the oil pressure light, fail safe realy.
Old 31-08-08, 07:13 PM   #4
dirtydog
Knob faced knobster
dirtydog's Avatar
Ah that's a good point I hadn't thought of that
Old 31-08-08, 07:59 PM   #5
fastdruid
fastdruid's Avatar
I've heard of people sanding LED's before to try and defuse the light some more. Might work for the back lights.
Druid
Old 31-08-08, 09:09 PM   #6
TSM
The Sick Man
TSM's Avatar
Druid
im gona try that, next weekend prolly
Curvey front rim and speedo. plowsie Stuff Wanted 7 17-12-08 11:13 AM
Curvey Speedo Not Working TSM Bikes - Talk & Issues 0 31-08-08 05:36 PM
Curvey rear light with clear lense & LEDs dirtydog For Sale - SV's and SV related items 0 19-07-08 07:59 AM
Curvey Speedo Drive Required NedSVS Stuff Wanted 1 03-03-07 08:56 AM
Curvey clocks (speedo, rev counter, instrument panel) jonnyt Stuff Wanted 1 01-08-06 09:25 PM
