Old 21-09-08, 07:39 PM   #1
Sean_C
Default Failed brake discs
I wonder if any of you can offer any insight as to why my disc has done this?
I rode to Pete and Lissa's yesterday morning, and at the top of their road heard a strange rattling noise. I hadn't heard it before, and I can't think that I did anything to provoke it. I haven't braked hard in the 200 odd miles I've done on the bike. Pete found the problem- a rattly brake disc.
These discs are brand new, have not undergone any hard braking (I've been taking it easy and using engine braking), I just can't see why they've done this.. apart from it being a dodgy disc that got through quality control.
There's loads of movement. The disc sounds like a tin can with a few nails inside it.. On the other disc, one of the rivets is loose too. Suzuki quality control problems?
I'll be calling the place where I got them from tomorrow morning to try and resolve the issue, before naming them- I don't think it can be their fault anyway.
Any ideas anybody?
Edit: They're 97-00 gsxr 600 discs by the way..
Old 21-09-08, 07:58 PM   #2
fastdruid
fastdruid's Avatar
Default Re: Failed brake discs
It's happened to me with GSXR disks before.
What I think happens is if the brake pistons are a little bit crudded up, one side will be stiffer than the other and will move the floating disk to one side, this will wear both the bobbin, carrier and disk until something fails and typically it'll be a wavey washer that fails, then the disk will rattle and even worse will flap round and force the pistons back in the calipers.
Druid
Old 21-09-08, 08:05 PM   #3
Sean_C
Thanks druid. Clean my pistons or possibly new pistons then?
Old 21-09-08, 08:45 PM   #4
fastdruid
fastdruid's Avatar
Well it wouldn't hurt to check but mine did this after thousands of miles not 200!
Druid
Old 21-09-08, 08:53 PM   #5
Sean_C
I was just thinking- surely this'd mean that anybody who hasslightly dodgy pistons buggers up their discs?
I'll still give them a ring to see whats what..
Old 21-09-08, 08:59 PM   #6
fastdruid
fastdruid's Avatar
Yeah that's what I mean, I suppose if one piston is totally and utterly stuck it may do it sooner but I still wouldn't expect it after 200miles!
Druid
Old 22-09-08, 09:21 AM   #7
Sean_C
I've called about them and two new ones will be on their way shortly. No fuss at all- excellent service from michelle at robinsons foundry she said that they've only had one set do the same as mine, only a couple of months a go- mightve been a bad batch. I'm well pleased
Old 22-09-08, 05:24 PM   #8
petevtwin650
Well Done to Michelle at Robinsons.=D>=D>=D>
Should have them fitted just in time for the RRR then Sean.
Brake Discs iffy SV Talk, Tuning & Tweaking 7 05-03-09 11:18 AM
Brake Discs LUMPY SV Talk, Tuning & Tweaking 25 19-01-08 04:49 PM
EBC Pro-Lite brake discs and Goodridge GH brake pads r4ce_e3nd For Sale - SV's and SV related items 7 14-04-07 07:37 PM
Brake Discs for GSXR front end conversion on SV 320mm discs Ter For Sale - SV's and SV related items 0 22-09-06 04:50 PM
Brake Discs cosmiccharlie SV Talk, Tuning & Tweaking 2 13-02-05 11:15 AM
