Old 11-10-08, 04:03 PM   #1
hallasv
Unhappy Sv650s 99-02 Instrument Dash
Hi all, first post here!
Quick question, I have the SV650s 99-02. The bulbs on the dash (Speedo/rev) have gone, so upon stripping the fairings and dash down I swapped the bulbs to 12v 1.7w if i recall rightly and only one of the bulbs worked on the right side of the revometer. Tried a working bulb still no good!
So stripped the instrument down and found the copper wiring to the middle bulb burnt out!? I read that this can be easy to fix for a qualified electrician as requires either new copper element or wire flex or something resoldered.
I'm from the Wigan area, know of any places that could fix this? Dont fancy having to buy a new instrument clock when could be a quick easy fix for a burnt wire.
Below is not the actual circuit, but is the same. Ignore the blue circles, the red circles are where the damage is to the bulb.
Cheers!
Old 11-10-08, 04:10 PM   #2
woodz61
Default Re: Sv650s 99-02 Instrument Dash
similar prob here
Old 11-10-08, 06:29 PM   #3
hallasv
Is there a way when swapping clocks to transfer the mileage over?
Old 12-10-08, 10:16 AM   #4
Dangerous Dave
Some of the clock backing shops can reprogramme KMH clocks to run as MPH so I guess it is possible, they alter the odometer to suit.
Old 12-10-08, 01:25 PM   #5
TSM
The Sick Man
TSM's Avatar
Fairly easy fix, just cut small strips of wire and solder them between any points that would bridge the circuit.
I had to do that as the track that did the speedo pulse had corroded though.
Old 12-10-08, 03:54 PM   #6
hallasv
Any size wire im guessing? I've got full access to 1mm above insulated ofc.
Or is it a journey to the friendly electrical store?
Old 12-10-08, 06:51 PM   #7
TSM
The Sick Man
TSM's Avatar
does not matter, 1mm will be fine
Old 12-10-08, 07:04 PM   #8
hallasv
Thanks for the help you gorgeous little man!!
2002 SV650s Instrument panel speedo panel mattglavin For Sale - SV's and SV related items 0 25-04-09 07:27 AM
Instrument and control locations sauluk SV Talk, Tuning & Tweaking 5 10-08-08 01:01 PM
2001 sv650s instrument lights? brett82 Bikes - Talk & Issues 0 20-05-07 10:03 PM
Removing Instrument cluster K6??? jvdairlie SV Talk, Tuning & Tweaking 2 14-11-06 11:23 PM
instrument bulbs Shinsei Jutsu SV Talk, Tuning & Tweaking 3 11-01-06 06:23 PM
