Old 13-10-08, 11:35 AM   #1
flimbar
Default Trouble replacing pointy screen
Just got a new screen for my pointy, having trouble getting the old one off.
The Haynes manual says "remove the well nuts" and shows a picture of some cylindrical nuts with a flange sitting proud of the faring popping out.
On my bike there's just like a rubber flange coming out of the holes were the screws went and I've pulled on these with close to the force I reckon before they will snap, are these supposed to pop out and pull the well nuts with them or something?
Old 13-10-08, 11:40 AM   #2
simesb
Default Re: Trouble replacing pointy screen
I found them very difficult to pull through - you can usually take the screen out with them in place. It can help to take the mirrors off as it loosens the front fairing.
Putting them back is a bugger tho.....
Old 13-10-08, 12:32 PM   #3
FG1
Don't try and pull the screen away without removing the rubber bungs. The screen has holes which the bungs go through. Have you removed the two screws from the top of the fairing.
Keep trying to pull the bungs out, they will come out. If it is proving difficult screw something into the bung, not too far, just enough to catch then use some pliers to pull at them.
Getting them back in is a piece of wee. Just drop them in a cup of hot water as you are positioning the new screen and they will be nice and supple for putting back in.
Old 13-10-08, 12:36 PM   #4
Girth
I removed my front end off the bike and fitted the all including the screen in about 15mins.
I just found the screen to come off easily, i think i removed the rubber bungs.
Old 13-10-08, 12:37 PM   #5
Brettus
+1 the hot water trick works a treat, as for getting them out I used a pair of needle nose pliers and grabbed as much rubber as I could, tease it out from side to side and it should come out.
this is the trickiest bit, once you have it sorted you will be well away
Pointy nekkid screen - where from? Jase22 SV Talk, Tuning & Tweaking 3 12-06-08 05:05 PM
std screen pointy 54 reg Jools'SV Now For Sale - SV's and SV related items 7 28-04-08 10:13 PM
Screen for a pointy Horney SV Talk, Tuning & Tweaking 15 04-11-06 07:46 PM
Pointy screen... Baph For Sale - SV's and SV related items 0 22-10-06 07:13 PM
Pointy screen fixings tigerprof SV Talk, Tuning & Tweaking 2 01-10-06 09:38 PM
