Old 27-10-08, 04:16 PM   #1
Mr Speirs
Mr Speirs's Avatar
Default Arrrrgggh. Bar End Screw Not Budging
Anyone got a clever way of getting these off.
Mine is not moving. Tried normal screwdriver. Rachet with Screwdiver bit (broke the screwdriver head). Tried heating it up with a heat shrink gun for a few mins to see if the glue (if theres is some) would melt and loosen. All with no luck.
Can anyone help me?
Old 27-10-08, 04:17 PM   #2
Sean_C
Default Re: Arrrrgggh. Bar End Screw Not Budging
Have you got an impact driver?
If you're not worried about the bar ends, you could use mole grips I guess, to see if that'd budge it.
Old 27-10-08, 04:18 PM   #3
plowsie
Just soak it in WD40 as good as you can, then screw back in then screw loose.
Old 27-10-08, 04:18 PM   #4
Sean_C
Or try penetrating oil.
Old 27-10-08, 04:22 PM   #5
Mr Speirs
Mr Speirs's Avatar
Have done the WD40 thing too.
Plowsie I can't get the damn thing to move at all let alone be able to screw it in first
You know how usually you can turn the bar end round whilst still on the bar well this is solid.
Old 27-10-08, 04:25 PM   #6
Spokey
they are only rubber bungs that the screw go into - just try pulling it out ?
or try and squirt some WD down inside - worth a try
Spokey ( formerly Nana )
Old 27-10-08, 04:27 PM   #7
plowsie
Right Chris, where are ya? Home or work?
Old 27-10-08, 04:27 PM   #8
Sean_C
My curvy clip ons were solid with a threaded hole through them, no rubber I don't think?
Old 27-10-08, 04:30 PM   #9
Mr Speirs
Mr Speirs's Avatar
Plowsie im at work. Lots of tools. Fancy a go?
Old 27-10-08, 04:30 PM   #10
Mr Speirs
Mr Speirs's Avatar
No rubber through mine. The other came off easy peasy and its threaded into the metal.
Got a screw in my tyre! bad-sv650 Bikes - Talk & Issues 10 04-02-08 06:16 PM
Screw ups The Hairy Hamish Pennine Massive 3 05-05-07 03:43 PM
Two up / Screw up John 675 SV Talk, Tuning & Tweaking 63 06-03-07 11:25 PM
tight screw hovis Bikes - Talk & Issues 13 04-01-07 01:45 PM
How do you screw up an oil change??? ls1bandit SV Talk, Tuning & Tweaking 29 19-09-06 10:55 AM
