Old 27-10-08, 04:47 PM   #1
hovis
Question multimeter Question
what setting should a mutimeter be on to check a battery
Old 27-10-08, 04:48 PM   #2
Default Re: multimeter Question
DC voltage 0-20V range to check whether it's charged
Old 27-10-08, 04:51 PM   #3
hovis
cheers
its been on charge since thursday, so im goin out this afternoon, then i will see what its like my mate has a multimeter and i have just watched this http://www.expertvillage.com/video/1...attery-two.htm i will check the battery when i get back, then again in a few hours
i will post results here
http://forums.sv650.org/showthread.p...59#post1668359
Old 29-10-08, 10:04 PM   #4
Baph
I know the question has already been answered, but can't help but say "that depends what you want to know!"
Old 30-10-08, 12:59 PM   #5
hovis
wether is fecked or not
Old 30-10-08, 01:14 PM   #6
454697819
oooh me me me... Iget to say it..
Hit it with a hammer...
then you will know!
Old 30-10-08, 01:47 PM   #7
Stu
Trinity
Stu's Avatar
So what else can a multimeter tell you apart from 0-20V?
Old 30-10-08, 01:51 PM   #8
Demonz
You still not figured it out yet? I was hoping for some instruction...
Old 30-10-08, 02:01 PM   #9
454697819
volts..amps.. current, continuety, resistance ... thats why its a Multi Meter..
Old 30-10-08, 02:05 PM   #10
timwilky
timwilky's Avatar
Also remember volts are both AC and DC. As stated above you need a 0-20 dc scale for you battery. But if you are checking your alternator output into your R/R then you would need an AC scale of about 0-100v.
When measuring current, you need to place it in series within the circuit not parallel. so please don't use it for any heavy loads like "I wonder what load my starter draws" etc.
Not Grumpy, opinionated.
multimeter help please Stu SV Talk, Tuning & Tweaking 11 29-01-09 11:19 PM
recomend me a multimeter hovis Bikes - Talk & Issues 21 05-07-07 08:33 PM
Cheap (£6) Multimeter at Aldi 2mths Bikes - Talk & Issues 4 16-06-07 03:25 PM
Multimeter wanted Stu Guildford Massive 9 20-02-07 11:01 PM
battery be reading on a multimeter? hovis Bikes - Talk & Issues 3 04-10-06 04:43 PM
