Old 29-01-09, 10:23 PM   #1
Stu
Trinity
Stu's Avatar
Default multimeter help please
How do I us a multimeter to find out if a +ve and -ve wires are shorting together?
Thanks
Old 29-01-09, 10:25 PM   #2
Kilted Ginger
Default Re: multimeter help please
more info required
Old 29-01-09, 10:34 PM   #3
First guess resistance test. But yeah more info!
Old 29-01-09, 10:37 PM   #4
Learningcurve
You need to put the black lead from your multimeter to an earth point (somewhere on the frame), then put the red lead on the ends of the two cables in turn.
Only the +ve should have a voltage reading if the switch for the circuit is turned off. If you have a voltage reading on the -ve wire, they are shorting.
Note: The switch for the circuit you are testing must be turned off to do this test!
Old 29-01-09, 10:42 PM   #5
Are you doing a leak test?
If yes, then set the meter to a resistance scale, (ohms, the Omega sign), a range of about 20 ohms is useful, make sure the bike is switched and off remove the leads from the battery, ensure that nothing touches the battery terminals. Clip the meter leads to the bike's battery leads, testing perfection requires no continuity at all, the real world says you may get a few ohms. If you get a significant reading disconnect the reg/rec, if the reading drops off the rectifier diodes are leaky.
Old 29-01-09, 10:43 PM   #6
theshed
tutorial here
http://www.ladyada.net/library/metertut/index.html
hope that helps
Old 29-01-09, 10:56 PM   #7
Stu
Trinity
Stu's Avatar
thanks all, but we have a winner
bit sneaky posting in SV tuning, but I'm soldering a gerbing wiring harness (I feckin hate soldering ) so want to make sure I'm not shorting any wires.
So as you say set the MM to Omega - 200 is the smallest and it reads 1 if I short the multimeter it goes to 00.5 so just replicate that with my wiring & hope it stays at a big fat 1
Cheers me dears
Old 29-01-09, 11:00 PM   #8
200 ohms is fine. The shorted meter reading you get could be used as a correction, but a reading that small won't affect things.
Old 29-01-09, 11:02 PM   #9
Stu
Trinity
Stu's Avatar
Hey it works to ensure I've got a good connection too. i.e. make sure it does fall to 0 instead of stay at 1
Old 29-01-09, 11:11 PM   #10
I could do nothing else but recommend connecting the leads of the meter to whatever it is that you're trying to measure.
It's kinda the reason for having the wires on the meter see?
multimeter Question hovis Bikes - Talk & Issues 11 30-10-08 03:56 PM
recomend me a multimeter hovis Bikes - Talk & Issues 21 05-07-07 08:33 PM
Cheap (£6) Multimeter at Aldi 2mths Bikes - Talk & Issues 4 16-06-07 03:25 PM
Multimeter wanted Stu Guildford Massive 9 20-02-07 11:01 PM
battery be reading on a multimeter? hovis Bikes - Talk & Issues 3 04-10-06 04:43 PM
