Old 19-11-08, 01:24 PM   #1
timwilky
timwilky's Avatar
Default How do I find out where the joists are
OK.
so the lounge is fresh decorated. New floor, new laminate, new skirting, new wall paper etc. I now need to hang the new radiator.
Simple position centrally on wall fit valves, drop pipe from valves and drill holes where pipe touches floor. But sods law applies.
My luck and sods law dictates there will be a floor joist at that exact position. So after the event and all the floor was up and I had the opportunity to measure/mark the joist position. How the hell do I detect the positions without going under the floor with a tape measure and a paper&pencil?. Don't tell me there is a standard spacing. This house was built by a guy called jack in the 50s who did not own a spirit level
Not Grumpy, opinionated.
Old 19-11-08, 01:30 PM   #2
jimmy__riddle
Default Re: How do I find out where the joists are
stud detector
Old 19-11-08, 01:40 PM   #3
timwilky
timwilky's Avatar
Will they work at that depth?
22mm floor then 3mm foam and 8mm laminate. I would have thought the flooring itself would have bounced back so much that the underlying joist would be lost.
Old 19-11-08, 01:47 PM   #4
jimmy__riddle
might work, if youve got one then its worth a try.
Old 19-11-08, 01:47 PM   #5
Sudoxe
Get a long piece of wood and draw a on the floor using a permanent marker.
Drill a hole, aprox every 1cm along the line to the depth of 1inch.
Get a pencil and poke it through each hole, if it goes straight through the laminate and floor board there isn't a joyce there. If it doesn't go through, there is.
Old 19-11-08, 01:51 PM   #6
timwilky
timwilky's Avatar
And get murdered by the wife for all the holes.
sod it, need to don the overalls early and go down into the depths
Old 19-11-08, 03:34 PM   #7
timwilky
timwilky's Avatar
So glad I checked before fitting
Placed centrally in the bay, both pipes would have collided with the joists.
so I have to place 2" off centre. I just know some criticising clown will say that it not centred
Old 19-11-08, 03:37 PM   #8
pmapp
pmapp's Avatar
Put an offset on yer pipe.
ooo - er missus
Old 19-11-08, 04:45 PM   #9
Gene genie
hit the floor with a hammer. listen to the sound and you'll work out where the joists are.
Old 19-11-08, 05:26 PM   #10
that would be ME !! if I ever visited.. how big is the cavity under the floor then Tim if you got in there??
Where can I find clutch housing bolts? - Cant find any mikeSV SV Talk, Tuning & Tweaking 2 24-03-08 12:30 PM
Trying to find an SV davidimurray Bikes - Talk & Issues 11 10-08-07 09:29 AM
I can't find........ svrash Bikes - Talk & Issues 0 19-02-06 03:26 PM
Would like to find... REEVESIE Bikes - Talk & Issues 2 17-04-05 11:01 AM
