Old 06-12-08, 04:27 PM   #1
etuna
Default Battery questions
My bike lives outside and because of no use for a fortnight/ cold, the battery is flat. Whirrs so not completely dead.
The previous owner let it go totally flat - if I jump it (cant trickle as live in upstairs flat so have no power point) will this be a constant problem? Should I buy a new battery?
ta
Old 06-12-08, 04:29 PM   #2
mustnt grumble
Default Re: Battery questions
ta
This happened on my old FZ6 and it was fine after bumping it.
Old 06-12-08, 11:11 PM   #3
ophic
ophic's Avatar
Car or bike batteries don't much like being totally discharged. If it happens too often, it won't hold charge anymore and you'll need a new battery.
Silver SV650SK3, Fuel exhaust
Old 06-12-08, 11:52 PM   #4
noob-saibot
what reading is considered totally discharged for a battery?? went out to mine after maybe 3 or 4 freezing days and below freezing nights and she refused even though battery was reading 12.something. first winter with the sv and im guessing vtwin+battery+cold=battery charger off santa
Old 06-12-08, 11:53 PM   #5
If you're not using the bike just take the battery out and put it on charge in the flat. It's only a few bolts to get it out
Old 07-12-08, 12:00 AM   #6
ophic
ophic's Avatar
Batteries can supply normal looking voltage with no load. But as soon as you crank it, that voltage will drop significantly. Open circuit voltage alone is a bad indicator of battery condition.
Old 07-12-08, 12:10 AM   #7
noob-saibot
Thought that alright. Think it dropped to 10 or 11 ish under starting load, but gave up the ghost after the 4th try. Would 4 freezing days and nights really knock a bit of stuffing out of a battery?
Old 07-12-08, 12:14 AM   #8
TSM
The Sick Man
TSM's Avatar
if replacing battery use YTZ14S, higher CCA than the stock
Old 07-12-08, 12:48 AM   #9
noob-saibot
Will a higher cca battery have any adverse effects?
Old 07-12-08, 12:58 AM   #10
metalmonkey
ta
If thre FI system spins up then you can bump start, as I have done to my bike several times. The best thing to do is, bump start it, then take it for a ride that will be far the best way of charging of it. Then if your not using the bike for a while, as above charge inside. Do you have an alarm on the bike? That reminds me I should put mine on charge.
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Questions questions...(funny noise,luggage, ferry) the_lone_wolf SV Talk, Tuning & Tweaking 23 23-05-07 07:19 PM
a few questions....well 5 questions....from a newb flynn209 SV Talk, Tuning & Tweaking 12 10-07-06 10:56 PM
Battery questions G - renamed SV Talk, Tuning & Tweaking 15 20-04-06 07:34 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
