Old 16-12-08, 07:30 PM   #1
etuna
Default Jumper packs only £19.99 from Maplins
thought Id spread the joy
now if anyone could walk me through the steps of actually using one on a pointy I'd be grateful
Old 16-12-08, 07:33 PM   #2
Default Re: Jumper packs only £19.99 from Maplins
I presume its the same way as a curvy. Put red croc on starter motor bolt(under rubber boot) put black croc on a main frame bolt. Turn on ignition, turn on pack......and clear!!!! oomph it starts. I do it this way as I'm lazy and won't take the seat off to the battery. YC told me to
dunno about pointies...only have curvies
Old 16-12-08, 08:42 PM   #3
SVDragRacer
I've used one on my curvey before exactly as dizzyblonde explained how to, but i think with the pointy you need to have enough life in the battery to actually prime the fuel system etc other wise you'll just be spining the motor over with just air going in.
Old 16-12-08, 08:44 PM   #4
etuna
it was whirring but not firing up so presumably there is enough juice. This was a week ago however......
Old 17-12-08, 11:33 PM   #5
I've had one of hte cheap maplins ones for ages, it's ace. Doesn't hold a charge too well now so I tend to keep it plugged in, but it's still a godsend. And it's got a tyre inflator too, which I use all the time for the pushbikes. Great buy!
Old 17-12-08, 11:50 PM   #6
Dave20046
Dave20046's Avatar
can't you just do it on the battery terms?
Old 18-12-08, 05:09 PM   #7
yes, cause you can. But why bother taking the seat off when your in a hurry, its a lot simpler
Old 18-12-08, 08:14 PM   #8
Dave20046
Dave20046's Avatar
Ah fair enough (just wondered if SV's had some weird electrickery that wouldn't allow it)...shame I don't know where the starter motor is
Old 18-12-08, 08:54 PM   #9
Baph
Doing it on the battery terminals would prime the fuel system, then you just hit the starter as usual.
Old 18-12-08, 11:36 PM   #10
you got a curvy? its that barrel shaped thing where the oil filter is.
Daryls one horse power jumper darylB Photos 24 26-02-09 11:19 PM
Maplins heated gloves, £9.99 bris Gloves 3 05-01-09 11:04 AM
Maplins Electrical testers going cheap! muzikill Bikes - Talk & Issues 0 19-06-07 09:01 PM
Maplins heated waistcoat and gloves - anyone tried them? thor Bikes - Talk & Issues 4 31-01-06 04:08 PM
