Old 19-06-07, 09:01 PM   #1
muzikill
muzikill's Avatar
Default Maplins Electrical testers going cheap!
They are doing 2 for one just now for 6 quid! - in store only!
Great little tester.
Maplins heated gloves, £9.99 bris Gloves 3 05-01-09 11:04 AM
Jumper packs only £19.99 from Maplins etuna SV Talk, Tuning & Tweaking 20 20-12-08 02:36 PM
Cheap Cheap Cheap New Hugger! SAMMY650 For Sale - SV's and SV related items 9 15-05-08 02:49 PM
Maplins heated waistcoat and gloves - anyone tried them? thor Bikes - Talk & Issues 4 31-01-06 04:08 PM
