Old 24-12-08, 09:10 PM   #1
MattCollins
Default Pointy, Curvey... What does it mean
I apolgise for the question. I did search (search is generally hit or miss on these boards especially when it is such a common term) and tried to find something in the FAQ section.
What is a pointy and what is a curvey?
Thanks
Old 24-12-08, 09:16 PM   #2
Default Re: Pointy, Curvey... What does it mean
A curvy is the original 99>02 bike, a pointy is everything since the 03 model.
Old 24-12-08, 09:17 PM   #3
vzzzbuxt
curvy = first generation SV650. 1999-2002 models so called as the fairings are 'curvy'
pointy =second generation of SV650. 2003 -current (reffered also as model K3 and upwards). so called because...... can you guess?? yep fairings are 'pointy'
there a bit more of a long winded geeky explanation, but ill save your boredom
Old 24-12-08, 09:18 PM   #4
Alpinestarhero
curvy' are better, pointies are crap. Unless they are the thou' which is ok, but not as brilliant as the tl1000s
Old 24-12-08, 09:18 PM   #5
Not really that geeky... the latr frames look pointy as well as the fairings!
Old 24-12-08, 09:19 PM   #6
silent11
look at this forums banner
Old 24-12-08, 09:22 PM   #7
Girth
All you need to know is that Pointy's are betterer than Curvys!
Old 24-12-08, 09:34 PM   #8
MR UKI (1)
Well said, big up the thou massive
Old 24-12-08, 09:59 PM   #9
bigspud
+1
Old 24-12-08, 10:12 PM   #10
sinbad
Curvies are most easily identifiable by the rider, who is generally without being prompted shouting things like "I has the bestest shape! Other types are rubbish!" and other things you'd associate with an inferiority complex
Can curvey 2 pointy markmoto SV Talk, Tuning & Tweaking 5 09-10-08 10:23 AM
curvey Vs pointy hovis SV Talk, Tuning & Tweaking 20 25-09-06 06:59 PM
Pointy cams in a Curvey... G - renamed SV Talk, Tuning & Tweaking 12 23-07-06 01:52 PM
Would a pointy exhaust fit curvey...... VR46 SV Talk, Tuning & Tweaking 2 29-03-06 03:52 PM
curvey Vs pointy apoc76 Idle Banter 0 08-01-70 02:58 PM
