i know i should really dig up an old threat that will probably have the answers but,on a whim today i purchased some brake fluid and copper grease thinking yeah the weather will be nice ill sort my brakes out, however the Haynes makes no mention of copper grease just silicone grease, so should i take it back or not??? also it says to replace the seals no matter what, is that necessary? and one last thing, would a spray can of air be any help drying wise and also to dis-lodge any debris???
sorry for probably repeating this for the millionth time Thanks!! |
#2 | |
If indeed you need to dismantle and overhaul the caliper then I think replacing the seals is generally accepted to be a good idea. I would. |
#3 | |
#4 | |
As YC says get some brake cleaner or carb cleaner (it's the same solution). I use wurth brake cleaner but that's probably overkill as it's only for cleaning, get the cheapest if you see fit.
hmm and some red rubber gresay stuff would be helpful too
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
Compressed air is good for getting pistons out and drying calipers after cleaning too.
It's generally recommended to completely overhaul calipers once a year. Road salt is a complete bugger and gets into everything- even behind dust/fluid seals. If you give the pistons a good dose of red rubber grease when putting calipers back together, it should keep all the nastiness out. Copper grease is also good for the pad retaining pins- stops them seizing in. Did my calipers last January (with still much appreciated help from DirtyDog) and the back caliper pins came out nice and easy the other week- despite all year riding and generally bad weather this year. I'm hoping the front will be the same. I also use copper grease on the bolt threads to stop them seizing. |
YC: It's a dab harsh to say that Haynes talk cobblers - they can't know a reader's level of mechanical understanding and thus can only recommend the route to a certain and safe outcome for a fix, particularly considering this is a safety consideration.
I've re-used brake parts on many occasions, but then I don't need to look in a manual to be told what to do, and most importantly I know what's safely re-usable and what's not - anyone who needs a manual to know what to do probably doesn't have the necessary level of experience to make such a judgement, thus recommending new parts is the only responsible course.
yeah i fully accept that i wouldnt be able to tell dodgy seals (you guys would probably get a are these seals ok thread with pictures!!) so will order some when i get the chance, so i also need soem red rubber grease and brake cleaner, sounds fair to me! be sure in the knoledge ill probably get stuck!!!
cheers |
#9 |
Anyone know where to get Red rubber grease from?
Found it on E-bay but really just wanted to pop down to a shop to get it. |
#10 |
What do you need it for? Does anyone know if there's owt in the service manuals about servicing the calipers or any how to's? Mine have probably never been done. I have found a useful post by viney but not much else.
cheers
Caliper Overhaul - No Bleedin Problem | I'm_a_Newbie | SV Talk, Tuning & Tweaking | 0 | 21-02-09 08:22 PM |
Brake Overhaul | Crash_Artist | SV Talk, Tuning & Tweaking | 3 | 18-02-09 07:44 PM |
Caliper Overhaul Kit | Cam_73 | SV Talk, Tuning & Tweaking | 6 | 16-06-08 02:32 PM |
Rear Caliper overhaul | Jimbo_Bimbo | SV Talk, Tuning & Tweaking | 3 | 12-08-07 12:43 AM |
Brake overhaul | Fuzz | SV Talk, Tuning & Tweaking | 4 | 13-03-06 11:51 AM |
