Old 25-01-09, 11:28 PM   #1
Ed
Default HID lighting upgrade
The headlights on my 675 are poor to say the least - I hate having only one light on dip. And on beam (two) they're not very good. The trip home from Ashbourne yesterday was challenging cos I couldn't see worth a damn.
So I'm thinking of a HID upgrade.
Before I splash out the shekels - has anyone done this upgrade to their bike (of whatever make)? What kit did you go for, 35/55? Will 55 burn out the wiring? Is the spend worth it? I need a plug and play thing as I'm hopeless with electrics.
I just found this one, Not cheap at all, I daresay there are others cheaper, this is just the first one I've come across, but I can't bear not being able to see where I'm going.
http://www.triumph-online.co.uk/dayt...sts-4872-p.asp
Anyone?
Old 26-01-09, 01:26 AM   #2
Default Re: HID lighting upgrade
55 will be fine as with any sense you will use a relay off the battery.
Do some of the leg work for us would you and find out what manner of bulbs the 675 uses...
Old 26-01-09, 04:12 AM   #3
2hys
ive had http://www.acumen-electronics.co.uk/ recomended to me, im going to look in to this for nxt winter as i could'nt see a dam thing on the way to work, luckly for me the old mans an auto elelky so will get a profesh install for beer money!
Old 26-01-09, 07:41 AM   #4
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Anyone?
55W will consume the same power as a 55W halogen bulb once it's running, but the HID systems draw a higher current when they start because they have to strike the arc and stabilise it, so you'll be running from a relay anyway or it'll blow the stock fuse repeatedly
also, you probably don't want to be installing HID on the high beam bulb, the HID systems take about 3 to 5 seconds to warm up and stabilise, during this time the light output goes from less than halogen to unsteady to stable - i wouldn't want to install it on a high beam where i could need to flash the lights to someone - stick to HID on the low beam and install a good halogen bulb for the high beam, if i end up with a daytona that's what i'll be doing
my SV kit was from www.HIDs4u.co.uk and i can't fault them for service or performance, if you insist on doing both lo/hi beam then you need kit #H1PROMB89 - £97.86 - to do just the lo beam then get #H7PROBIKE - £48.93
one thing you don't mention is temperature, 6000K will look white with a blue tint, 4300K will look similar to halogens and output more light (not that 6000K is short on light output though...)
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-01-09, 07:42 AM   #5
Ed
Oops. Yes. It has a 12v 55w H7 left, 12v 65w H9 right.
Old 26-01-09, 08:58 AM   #6
Which SV do you have Pointy or Curvy? Was it easy to do?
Ta
Old 26-01-09, 09:30 AM   #7
the_lone_wolf
Captain Awesome
Ta
Pointy SV and it's dead easy as long as you have a basic idea of building circuits, soldering etc etc
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-01-09, 09:52 AM   #8
Damn a pointy, plus my least favourite subject, electrics
Old 26-01-09, 10:30 AM   #9
Ed
Oh I hear you
TLW - thanks for the link - a lot cheaper than the one I found. I regard it as a safety mod rather than a cosmetic one.
Incidentally in my earlier post 'left' means nearside and 'right' means off.
Old 26-01-09, 11:29 AM   #10
As TLW says, better to leave the high beam one as a halogen, perhaps just fit a better bulb of the same wattage.
Does dip beam stay on when you switch to main?
import mot lighting the g SV Talk, Tuning & Tweaking 2 24-03-09 07:36 PM
Aux lighting. rictus01 Bikes - Talk & Issues 3 13-02-09 02:08 PM
HID lighting erics02 Bikes - Talk & Issues 28 26-10-08 08:33 PM
HID lighting the_lone_wolf Bikes - Talk & Issues 71 02-07-08 04:48 PM
Problems with lighting Raiden SV Talk, Tuning & Tweaking 4 12-06-07 07:29 PM
