Old 26-01-09, 12:59 PM   #1
Alpinestarhero
Default Dust AND piston seals?
Hi all, quick query I want clarified quick:
I rang suzuki spares direct to ask about dust seals for the front calipers, they said they only do a kit which is a dust seal and a piston seal at about £26 per caliper; this sounds far far overpriced to me.
I know what the dust seals are, but where does the piston seal come into play?
Matt
Old 26-01-09, 01:06 PM   #2
jambo
jambo's Avatar
Default Re: Dust AND piston seals?
Piston seal is the fluid seal that sits behind the dust seal. The thicker of the 2 seals it provides the piston / caliper / fluid barrier.
They lead a much easier life than the dust seals, provided the caliper is looked after at all.
try shop.wemoto.com as they do full seal kits for both front calipers for £33
Jambo
Old 26-01-09, 01:18 PM   #3
Alpinestarhero
Cheers jambo, i'll run along to suzuki spares who do it for the same price later on
then on saturday, I get my front brakes reknewed although then i cant be lazy with my hill starts.
Old 26-01-09, 01:39 PM   #4
husky03
pm'd
Old 26-01-09, 03:29 PM   #5
branny
Has anybody ever had trouble with leaky piston seals?
I just greased all my front brakes up and i just cleaned up and rubber greased the seals.... a fella here at work seems to think new seals is the only way.
They didn't look damaged in any way... just wondering if anybody has known them to leak after being dislodged.
Old 26-01-09, 05:23 PM   #6
Dangerous Dave
Originally Posted by jambo View Post
Piston seal is the fluid seal that sits behind the dust seal. The thicker of the 2 seals it provides the piston / caliper / fluid barrier....
....try shop.wemoto.com
+ 1
Were the pistons cleaned with scrotchbrite before you put them back in?
Old 26-01-09, 05:25 PM   #7
branny
i used some very fine wet and dry.
Old 26-01-09, 05:27 PM   #8
Dangerous Dave
Sounds like you need a new seal then, try wemoto.
Old 26-01-09, 05:30 PM   #9
branny
ahh, sorry for the confusion... i don't have a leak! I was wondering how common leaky pistons are as i did not replace the seals, i just regreased them.
Somebody here seems to think once removed, they will leak at some point. when it comes to brakes... well, i don't really want them leaking!
Old 26-01-09, 05:32 PM   #10
Dangerous Dave
I have removed pistons and cleaned them up before placing them back into the old seals with out a problem, I do not recommend that you keep doing it though.
Front calipers: no dust seals tubbycyclist Bikes - Talk & Issues 14 02-01-09 03:14 PM
Brakes - Dust seals removed. Grinch SV Talk, Tuning & Tweaking 7 19-02-07 04:20 PM
Dust Seals TSM Bikes - Talk & Issues 5 01-09-06 10:10 AM
Brake Dust Seals leegriffiths128 SV Talk, Tuning & Tweaking 2 16-12-05 06:59 PM
Caliper piston seals normas_glasses SV Talk, Tuning & Tweaking 1 31-01-05 08:04 AM
