Old 18-02-09, 10:23 AM   #1
AndyBrad
Default progressive springs
Ok folks, Im off to YC’s tonight to drop some springs in the front of my bike. There progressive suspension springs for the 1999 curvy (no adjuster cap). Ive have a look at the instructions and it says trim the spacer to suit. Nowthen. Just so I know in my own mind what were doing im thinking that this means we need to shorten the spacers already in there. However I ve measured the springs and there significantly longer than the stock spring length. So is it just a case of shortening the spacer so it’s the same overall length? Or do I have to measure my weight and do some calcs?
Cheers.
Old 18-02-09, 10:26 AM   #2
Default Re: progressive springs
your not a fat bum, so i doubt you'll need spacers, but YC will sort you out anyway...hes got a load that came out of one of mine
which incidently I didn't know there were spacer already in there...hope he put summt back in *confused blonde look*
ps don't worry about them being longer than stock. Mine were too
Old 18-02-09, 10:36 AM   #3
Luckypants
Luckypants's Avatar
No doubt Y-C will sort it out for you, but the spacers need trimming so that the preload on the spring is right for your weight. Normally done by sitting on the bike in riding kit and measuring.
Old 19-02-09, 01:09 PM   #4
AndyBrad
Ok got these fitted at yc's lasst night with 10w oil. Nowthen im not too sure what improvement i should be looking at. However it is definaly less crashy over bumps and potholes (of which they are many) are much less of an issue. It also seems to handle corners better and has a little less wobble if i brake or accelerate mid corner.
Nowthen it also apears to have a bit more travel than before. We set the air gap to 140mm as per the springs instructions but i know 110 is standard. Could somone tell me what this air gap does? Also it rattles on about preload. Now we set them to the same length (overall) as the standard one but there appears to be a little more travel? not too sure though. Would sticking a couple of washers in there help this?
Oha nd does anyone have some of those adjusters that would fit a curvy? Not that i actually will be needing them but just bacause i havnt spent any money on the thing in the last 12 hours
Old 19-02-09, 01:10 PM   #5
AndyBrad
oh and what to stick on the rear? thats cheap!
Old 19-02-09, 01:14 PM   #6
just swapping the rear could counteract the teething probs with the front. You could look on ebay for a stock shock with very very few miles on it. I've just put one on with 1500 on it, and its improved the pogostick style down, and taken a little more banging off the front. I now know that putting 10w oil in last time was a mistake, but we kinda knew that. If your not into chopping stuff up, Hagon is a direct replacement, but they cost 250 quid new. I've got the full lot on the yellow SV, and they work perfect in tandem. You may be lucky to find a low mileage one on ebay, I know Pmapp did.
Old 19-02-09, 01:23 PM   #7
We fitted them with effectively 30mm of preload from relaxed state.
Oil air gap, as I understand it, acts like a second spring which is in parallel with the main spring so the rates basically add up. This affects the rate under hard braking when the forks are compressed.
Changing the springs does NOT affect the total travel. Total travel is distance between the top out spring and the hydraulic lock piece (bump stop). If the forks had 100mm of range before they still have the same.
Rear shock depends on your weight and inside leg.
SRAD750 is nice, but soft and tall.
ZX6R is harder, better damped and not much taller.
do the cable tie trick like I said, go and brake hard and see how much travel you are using. I have never had much luck taking sag measurement on the front.
Old 19-02-09, 02:16 PM   #8
AndyBrad
What about srad 650?
Ill give it a go tomorrow if my legs still work after tonight
Old 19-02-09, 03:18 PM   #9
no such thing as an SRAD 650
SRAD600 is really tall. Not sure if it's too tall.
Old 19-02-09, 03:28 PM   #10
AndyBrad
Oh ok. Ive taken a quick look at a zx6r and there only about 35 quid. Any year to go for? And what are they like to fit?
Progressive SV SPrings gettin2dizzy For Sale - SV's and SV related items 15 14-04-09 09:22 AM
Progressive springs for curvy Aiki For Sale - SV's and SV related items 3 21-10-08 09:36 AM
WP progressive springs r4ce_e3nd For Sale - SV's and SV related items 1 16-04-07 03:16 PM
HAGON Progressive springs Italianjob SV Talk, Tuning & Tweaking 7 19-08-05 04:43 PM
Progressive springs wolverine04uk SV Talk, Tuning & Tweaking 7 04-05-05 01:51 PM
