Old 19-02-09, 03:03 PM   #1
mikebrooman
Default Intermittent Neutral Light
The 'N' light on my K2 is playing up. Intermittently goes off, meaning it's on most of the time irrespective of gear, and flashes off for a millisecond over each bump. Sounds like a loose wire, but surely a loose wire wouldn't turn it on, but turn it off. Can someone give me some tips where to start wiggling?
Thanks
Old 19-02-09, 03:25 PM   #2
Default Re: Intermittent Neutral Light
The neutral light is always live, it's earth side is touched onto the engine case in neutral. Thus if the wire from the light to the switch has damaged insulation, and were to touch to earth the light would come on. Look for damaged to that wire, I reckon you'll find some.
Old 19-02-09, 03:28 PM   #3
mikebrooman
Will do that thanks.
Neutral Light DarrenSV650S Bikes - Talk & Issues 3 09-05-09 05:12 PM
FI Light flashes - intermittent starting trouble. mark__lewis SV Talk, Tuning & Tweaking 3 16-04-09 02:10 PM
Me being a numpty - no neutral light and fi light is on Whitehouse SV Talk, Tuning & Tweaking 8 03-04-09 03:50 PM
False neutral light JediGoat Bikes - Talk & Issues 11 05-09-07 09:14 AM
Neutral Indication Light? MitchC SV Talk, Tuning & Tweaking 6 01-04-05 08:15 PM
